20 Most Recent Casio Exilim EX-Z50 Digital Camera Questions & Answers
My speakers had a high voltage now they are not working, what the problem be and how can i fix it
Is this a problem with your camera? Or speakers? It would help if you would tell us what type of speakers you have and what you mean by "a high voltage." How? From the limited amount of info here I can only guess you blew a fuse in the unit.
7/24/2013 9:27:58 PM • Casio Exilim... • Answered on Jul 24, 2013
Dropped Casio EX-Z50. The lens remains 1/2 out, power goes off
Try the procedures in this tip.
1/25/2013 2:47:28 AM • Casio Exilim... • Answered on Jan 25, 2013
I'm looking for a driver for vista, can you please
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
1/25/2013 2:47:15 AM • Casio Exilim... • Answered on Jan 25, 2013
Power on
1/25/2013 2:46:51 AM • Casio Exilim... • Answered on Jan 25, 2013
Software with camera does not support Vista
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
1/25/2013 2:46:26 AM • Casio Exilim... • Answered on Jan 25, 2013
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1/25/2013 2:46:13 AM • Casio Exilim... • Answered on Jan 25, 2013
Every time I take a picture it says card error even bought a new card
What type and size memory card? The EX-Z50 works with MMC and SD cards. While higher-capacity SDHC cards will fit into the slot, they are electronically incompatible and will not work.
1/9/2013 4:07:17 PM • Casio Exilim... • Answered on Jan 09, 2013
2answers
Card is locked up
Here are other troubleshooting steps if the slide switch does not correct the problem:
12/15/2012 5:51:08 PM • Casio Exilim... • Answered on Dec 15, 2012
Casio ex-z50 lens doesn't open
12/6/2012 4:35:52 AM • Casio Exilim... • Answered on Dec 06, 2012
0answers
Lens error
9/14/2012 9:33:24 PM • Casio Exilim... • Answered on Sep 14, 2012
2answers
Hi When power on, i have
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/11/2011 11:14:12 AM • Casio Exilim... • Answered on Jul 11, 2011
I have a Casio ex-Z50
if the pictures are dark it means either the flash is not enabled..or it is in a mode that not allowing the flash ...Just look in the menu and first set the factory settings to reset it to the original state ..after that what you should try one by on e..are the modes...it has indoor mode...outdoor...bright mode..and so on ...For example if it is set on a bright mode..it will dark the pictures cause it assumes that you shoot on a very bright environment ...to change it ..just set from modes..by selecting the normal mode...and activate the flash ..
1/19/2011 5:59:07 PM • Casio Exilim... • Answered on Jan 19, 2011
I have a screen and
Some useful sites:
http://www.myfixtips.com/blog/digital-camera/how-to-replace-lcd-screen-on-canon-sd870is-215.htm
The steps given are for different cameras, but it may help.
Hope it may be useful.
1/6/2011 1:36:10 AM • Casio Exilim... • Answered on Jan 06, 2011
I have an Exilim X-Z50
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/26/2010 10:36:08 PM • Casio Exilim... • Answered on Dec 26, 2010
Green light flashing but nowt
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
9/2/2010 4:23:00 AM • Casio Exilim... • Answered on Sep 02, 2010
The screen says OeO2
That is a system error related to the automatic focus and since it is caused by a failure in the integrated components of the camera, it needs to be sent in to be fixed (i.e. the camera replaced under warranty) Call 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
4/29/2010 8:01:57 PM • Casio Exilim... • Answered on Apr 29, 2010
Casio Exilim EX-Z50 Digital Camera Logo
49 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
when power
  • Cameras
