20 Most Recent
Canon PowerShot A40 Digital Camera Questions & Answers
I have a canon pc1019 digital camera,and how i
thats also known as a powershot a40 - heres the support site for that camera
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=221&modelid=8288
if you goto the drivers and download tab - here you will find a manual - for zoom browser and the camera
You should be able to connect the camera to your computer with a supplied USB cable - and then the zoombrowser software should detect your camera connected and offer to transfer images
In the manual on Page 126/128 explains how to connect camera to PC
Also explains in the manual how to transfer the images.
If your PC has a memory card reader you can transfer that way - also explained in the manual
I haVE A 40 CAMERA
From the REC menu, select Setup and then select Format.
Full instructions are in the "Formatting a CF Card" section of the manual (page 98 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/7/0900001157/01/PSA40A30CUG-EN.pdf
How do I transfer pictures from my camera to the
images are stored on standard Type I CompactFlash cards. Consider the included 8 MB card a starter capacity, since its 12-picture limit means you'll need to return to your computer often to transfer images and free up the card for more pictures. A 128 MB card is a great size for this camera, storing around 200 images. To transfer images to your computer, simply attach the included USB cable between your PC and your camera. Your computer should automatically recognize your camera and let you move the pictures to your hard drive. Simply click on my computer click on new drive shown in this folder, select all the pictures, copy them and past to your desired location,
you can also copy picture by using card reader, put the SD card in card reader and follow the same procedure
Good luck, do rate the solution if helped
Upgraded to Windows 7. Canon software says the
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or Windows Photo Gallery or any other photo cataloging program.
Download A40 Digital Camera driver
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I have a canon powershot
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Hello, I am trying to download the software I need
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a40#DriversAndSoftware
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
I have a Canon A40
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
I just bought a canon powershot A40 off a person,
My computer won't recognize the
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
