20 Most Recent Canon EF 75-300mm f/4-5.6 IS USM Lens Questions & Answers
Error message "01"
This could be as simple as cleaning the pins that are used to communicate between the lens and the camera. Use a pencil eraser on the lens pins and camera connectors.
1/21/2019 6:13:36 PM • Canon EF... • Answered on Jan 21, 2019
I have a Canon EF 75-300 lens that I am using with
Camera electronics are fubar.
6/26/2017 1:45:33 AM • Canon EF... • Answered on Jun 26, 2017
2answers
Blurry pictures of moving wildlife
check shutter speed, problem to slow, increase aperture if light level permits hand shake can also blur image.If in full auto mode change to manual settings mount camera onto tripod THIS WILL SOLVE HAND SHAKE PROBLEMS the most common cause of blurred images.
3/14/2016 8:02:50 PM • Canon EF... • Answered on Mar 14, 2016
Can you give me the instructions on how to assembly/disassemble the ef 75-300 f/4* lens?
you can get it on ebay.com for cheap price .But first - try to look it for free on google.com. Sometime you can easily find it.
8/12/2014 1:49:10 AM • Canon EF... • Answered on Aug 12, 2014
Where is the on off switch on canon 75mm-300mm is usm
There isn't one The lens is powered from the camera battery and when the camera is switched off no power goes to the lens. So in effect the off switch is on the camera.
8/3/2014 9:37:06 PM • Canon EF... • Answered on Aug 03, 2014
Tripod mount for canon 75-300 mm lens
The XTi (400D) needs to be attached firmly to a tripod with a tilting head to enable you to counteract this.
8/3/2014 9:34:53 PM • Canon EF... • Answered on Aug 03, 2014
Trying to find on-line instruction manual for
Lenses don't usually need instruction manuals, only specifications. What do you want to know? Maybe i can help answer your questions...
2/2/2010 2:05:24 PM • Canon EF... • Answered on Feb 02, 2010
2answers
My IS lens has a
eBay is your best bet.
Thanks
1/20/2010 11:12:27 PM • Canon EF... • Answered on Jan 20, 2010
Need user manual for Canon 75-300mm IS USM lens
Canon have never issues the user manuals for the lenses in pdf format. The only way you will get one is if somebody has scanned your particular models manual. I have just got immaculate manuals for some of my lenses from Ebay. There is one on ebay now. Type this auction number into the search box. 270237270981
1/17/2010 8:43:02 AM • Canon EF... • Answered on Jan 17, 2010
I have a Canon Rebel XT, I have a 75-300mm lens.
Sorry, no, different mounts and electronics prevent that from being possible
12/7/2009 8:56:29 PM • Canon EF... • Answered on Dec 07, 2009
Canon 75-300 IS lens
1/19/2008 3:15:41 PM • Canon EF... • Answered on Jan 19, 2008
Canon 12x36 is ii stabilization is not working properly. Stabilization tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
3/21/2024 12:18:08 AM • Canon Cameras • Answered on Mar 21, 2024
Canon Prima BF-800 Zoom Compact Point and Shoot Zoom Camera. I can't use the date feature?
The date feature has to be set up and there is always a way to turn it off and on. I was looking for a manual, but this is not a North America model. This link might work better for you.https://www.google.com/search?q=canon+prima+bf-800+zoom+manualThe Error Codehttps://www.google.com/search?q=canon+prima+bf-800+zoom+hr+ha+errorMake sure the batteries are good!..
2/18/2024 8:48:21 AM • Canon Cameras • Answered on Feb 18, 2024
I have problem with my canon a95 a Change battery but still my camera say me to change a battery
If you are using Nickel Metal Hydride rechargeable batteries, they have come to the end of their lifespan. Buy New or use AA Lithium batteries. https://www.google.com/search?q=canon+a95+battery ..
2/15/2024 10:55:54 PM • Canon Cameras • Answered on Feb 15, 2024
My Canon AV1 only shoots in B mode, the light meter works correctly, and everything else seems fine. Has anyone had the same issue and found a solution?
If your Canon AV-1 is only shooting in Bulb (B) mode, it could be due to a malfunctioning shutter or aperture control. However, since the light meter is working correctly, it is possible that the issue is with the camera's shutter speed dial. The shutter speed dial is located on the top of the camera and should be set to a specific speed when shooting in aperture-priority mode. If the dial is stuck in the Bulb (B) position, then the camera will only shoot in bulb mode. I would recommend taking your camera to a professional camera repair shop to have it inspected and repaired if necessary.
1/21/2024 11:01:27 PM • Canon Cameras • Answered on Jan 21, 2024
Any instructions about repairing Canon Legria HF200?
Real help that is not AI Generated! Articles and instructional videos https://www.google.com/search?q=canon+legria+hf200+clean+lens+and+sensors ..
12/30/2023 9:14:41 PM • Canon Cameras • Answered on Dec 30, 2023
2answers
Canon PowerShot G5 Camera. Can the LCD screen on the Canon G5 be repaired of replaced?
Yes of course. Take it to your local Canon Service Centre. https://www.google.com/search?q=Canon+Camera+Service+Centre ..
12/14/2023 11:09:56 PM • Canon Cameras • Answered on Dec 14, 2023
Canon EF 75-300mm f/4-5.6 IS USM Lens Logo
Popular Tags
17 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
trying find line instruction manual
  • Cameras
