20 Most Recent
Canon PIXMA MP280 Multifunction Printer - Color- 43 Second Photo 4800 Questions & Answers
How can I remove rear panel to clean out paper drive?
content.etilize.com/User-Manual/1017865665.pdf
See Operation Panel. .... Lights or flashes orange when an error occurs, such as paper-out or ink-out. .... You can switch the size of paper loaded in the Rear Tray between A4 and 8.5" .... Remove the original on the Platen Glass after scanning is completed...... For details on the printer driver settings, see Printing Documents.
Canon printer crumbles up on the left side
look for something stuck in roller by pulling up on the front scan glass- you see the rollers- clean with dry clean cloth- don't use paper towel= too dusty
once the paper is clear, print and while it pulls one side of paper down first, hold it with your fingers and guide it in- do this 3 times and it will get better until it works on its own be patient and it will work- its a 99 dollar printer after all - good luck all
Canon pixma MP280 error31
hi, error31 and others can be cleared by holding the reset button down until it sounds like it wants to print- push scan and start
should be no error and work fine you have to hear the printer work after reset is pressed or you reset again until it works hold button for ten to fifteen seconds 10-15
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
