20 Most Recent Canon EF-S 18-55mm f/3.5-5.6 USN Lens Questions & Answers
18answers
Auto Focus not working for Canon EFS 18-55mm lens
Pulling gently on the focus ring worked for us. Exactly what the Dr. ordered. Slight pop, maybe 1/16" movement, and the lens is working again!
9/30/2018 9:53:40 PM • Canon EF-S... • Answered on Sep 30, 2018
Canon EF-S 18-55mm f/3.5-5.6 USN Lens won`t auto focus
Try cleaning the electronic contacts on the lens and camera.
6/30/2017 8:57:54 AM • Canon EF-S... • Answered on Jun 30, 2017
0answers
5answers
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
4/8/2017 9:09:47 PM • Canon EF-S... • Answered on Apr 08, 2017
Repair - How can I fix a broken lens/AF/MF?
If you have another lens, try that on the camera to determine if the damage is the lens or the camera. If the lens is damaged, just buy a new one, I would not trust the elements to focus true on a lens that has had an impact severe enough to cause this problem. As this is the standard lens that ships with most Canon Packages, you can likely find a cheap one online.
9/10/2016 6:27:48 PM • Canon EF-S... • Answered on Sep 10, 2016
My canon rebel xs 18-55 lens wont auto focus
Replace the broken ribbon cable in the lens
9/2/2016 10:42:19 PM • Canon EF-S... • Answered on Sep 02, 2016
I dropped my camera and hit the lens and now auto focus does not work
You'll probably need a professional repair. Compare the cost of repair with the cost of replacement. On that lens it could be about the same.
9/2/2016 10:34:19 PM • Canon EF-S... • Answered on Sep 02, 2016
2answers
18-55mm lens wont auto focus
If the lens will focus on manual focus but won;t on auto focus you may have a ribbon connector failure in the lens. This ribbon continually flexis as the lens moves in and out. Over time this can break and will probably need to be replaced. All good camera repair shop should be able to do this for you and this remady is one of the cheaper repairs to photographic equipment
4/13/2016 11:09:18 PM • Canon EF-S... • Answered on Apr 13, 2016
2answers
Autofokus dont work
Probably a broken ribbon cable connector
3/25/2016 8:16:49 PM • Canon EF-S... • Answered on Mar 25, 2016
Canon efs 18-55mm lens will not take pictures with af on
Hi this is because flex cable damage. Lens does not know exact position of focusing lens, so it fails to work in AF mode. Problem is fixable but not DIY. Should cost around 40USD (35Eur). Regards
3/3/2015 10:35:33 AM • Canon EF-S... • Answered on Mar 03, 2015
Canon lens 18-35 tries and tries to focus
If the focus works OK in manual focus and you are getting problems with auto focus you may have a broken or worn ribbon in the lens.
12/27/2014 10:20:26 AM • Canon EF-S... • Answered on Dec 27, 2014
Camera displays flashing green light and will not take photo
If you flip the M/AF switch on the side of the lens and the then the camera takes a photo, Then the focus drive gears are damaged in the lens and needs repair,
11/25/2014 4:57:44 PM • Canon EF-S... • Answered on Nov 25, 2014
How can I fix auto focus not working Sigma 18-250mm lens?
Take it to a camera shop.
8/29/2014 5:18:04 AM • Canon EF-S... • Answered on Aug 29, 2014
I have a scratch to the lens of my canon efs 18-55mm
I'd say yes as the replacement cost for this lens would probably exceed the repair cost
8/6/2014 7:12:24 PM • Canon EF-S... • Answered on Aug 06, 2014
I have a Canon 1000D wth the kit EF-S 18-55mm lens supplie dwith it. The lens does not show any of the auto-focus points when I hold the button halfway down. Is this becquse of the broken cable proble
The symptoms you've described are that of the possibility of a broken ribbon cable. As the second lens works on both cameras then the strong possibility is that it is the lens at fault and not the camera. Another quick test would be to put the 'faulty' lens on manual focus and check that it will focus in that mode. To replace a ribbon cable is not too expensive. With all items of modern photography they have intricate electronic circuitry and the definitive problem will only be known once a competent repairman takes the lens apart, but I think you've worked out the problem.
8/6/2014 8:23:22 AM • Canon EF-S... • Answered on Aug 06, 2014
Auto focus does not work on canon eos 300d camera
It may be that the ribbon connector has broken in the lens.
8/3/2014 8:50:17 PM • Canon EF-S... • Answered on Aug 03, 2014
Canon Ef_S 18-55mm f/3.5-5.6 Lens won't focus in manual or auto mode
If the camera is used you may have a problem with the seller. Before jumping into conclusions however read your manual for your solution or simply search youtube for a help video. Hopefully this helped.
2/15/2014 11:56:28 AM • Canon EF-S... • Answered on Feb 15, 2014
Mistake on last post - my brand new Canon EOS6D
Since it is a brand new camera, take it back to the shop where you bought it. There isn't really anything you can do.
11/29/2013 12:48:32 PM • Canon EF-S... • Answered on Nov 29, 2013
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
Popular Tags
76 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
auto focus not working canon efs 18 55mm
  • Cameras
