20 Most Recent
Motorola Mobility DROID RAZR Maxx 4G Mobile Phone - Black Verizon Wireless MOTXT912M Questions & Answers
How can I track and recover?
Hello Jessica,
You can track your phone with A
ndroid Device Manager using your computer
if your device was synchronized with your gmail account, but your device needs to have GPS and also data or WiFi connection active to be able to track the device, you can also use android device manager to delete all the information on your phone. Here is the link for more information:
Turn Android Device Manager on or off
Best Regards,
Kenny
Motorola Support
11/23/2016 2:42:12 AM •
Motorola...
Answered
on Nov 23, 2016
Getting the view bacc
Hi Courtne,
In that case you will need to do a Factory Data Reset to your device, In this link DROID Master Reset Factory Data Reset you will find the steps of how to do it.
Regards,
Maya
Motorola Support
7/7/2016 8:41:16 PM •
Motorola...
Answered
on Jul 07, 2016
How do I block calls and text
download escan antivirus. it has many feature like call block, msg block, backup and restore data and contacts.
12/15/2015 4:50:51 AM •
Motorola...
Answered
on Dec 15, 2015
Removing battery
This phone has a non-removable battery.
Mark
Motorola Support
1/6/2015 12:56:29 PM •
Motorola...
Answered
on Jan 06, 2015
Dropped cell phone in water
Put the phone in a bag of rice, it absorbs the moisture. It might save the phone, I worked for my brother.
12/31/2014 12:10:58 AM •
Motorola...
Answered
on Dec 31, 2014
How do I unblock a contact on my Android phone?
Hi first of all go into the settings menu and select my device. Look for the blocking mode and make sure it is turned off if not turn off. That should unblock every thing. I hope this helps
12/9/2014 4:13:31 AM •
Motorola...
Answered
on Dec 09, 2014
Why does my driod go right to voicemail
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Mark
Motorola Support
8/28/2014 2:37:01 AM •
Motorola...
Answered
on Aug 28, 2014
Error code 3002 for Pandora
Remove and reinstall the Pandora app. Contact Pandora support if you still have issues.
Mark
Motorola Support
8/28/2014 2:24:50 AM •
Motorola...
Answered
on Aug 28, 2014
Axx
You can sync photos via the google photos cloud sync function. Then download them directly to your PC. Syncing to phone via cable is unnecessary.
mark
8/26/2014 2:33:20 AM •
Motorola...
Answered
on Aug 26, 2014
