20 Most Recent Buffalo Technology Buffalo AirStation Broadband Router AP Wireless (WBR-G54) Questions & Answers
2answers
TRYING TO CONFIGURE WIRELESS CONNECTION WITH NEW
Check the wireless router for the security key and insert
1/11/2018 5:16:56 AM • Buffalo... • Answered on Jan 11, 2018
2answers
Air station keeps cutting out - client manager
first i would download and install this program http://www.xirrus.com/library/wifitools.php that will tell you all the networks being broadcast and what channel they are on ideally you want to be on channel 1 or 6 or 11 - as they do not overlap
you should be able to download a manual from here http://www.buffalo-technology.com/support/downloads/
you need to login to the router and then goto the wireless section and changed the channel there
looking at this model http://www.buffalo-technology.com/products/wireless/wireless-g-125-high-speed/
3/22/2017 6:46:15 AM • Buffalo... • Answered on Mar 22, 2017
0answers
Previously used on another PC and now trying to
check the ip address + mask
2/6/2011 2:03:36 PM • Buffalo... • Answered on Feb 06, 2011
I've had a new laptop
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
12/27/2010 5:03:40 PM • Buffalo... • Answered on Dec 27, 2010
Forgot admn passwaord
Create a password reset CD on another computer, then boot from CD in the locked computer, and it will allow you to reset your password.
Click HERE
to get the software and read the instructions carefully.
5/19/2010 7:16:07 AM • Buffalo... • Answered on May 19, 2010
My son's ipod cannot connect with our internet?
You may want to check and see what kind of connection limitations are in place.
The router should have a static IP address *(like 192.168.1.1) or something close to that written on it.
You can use your web browser to log into your router and look at the settings.
Go to the Buffulo website for specific guidance on your model router.
12/28/2009 3:00:25 PM • Buffalo... • Answered on Dec 28, 2009
2answers
Device password requested on 1 or 4 laptops, 1 laptop can wiifii and no wiifii on the others
u set up ur buffalo airstation on the 1st laptop tat is working fine,,and at tat time u secured ur wireless network.so tat no one can else can connect to it..specially ur neighbours..u have to use tat password on the new computer.and tat will do it
8/13/2009 7:02:52 AM • Buffalo... • Answered on Aug 13, 2009
Dell Latitude and buffalo client manager problems
I have just had exactally the same problem,
Right, what you need to do is, go to "help & support" for the start menu, when that has loaded search device manager.
Then click on the first [yellow] question mark you see under "network adaptors". The it will come up as, a property box, then click re-install driver, during the process of re-installing a box will appear, like mine did as we both have the same computer/laptop,saying something like; "window's dose not support this" there are 2 options continue installation or stop, click continue & then go to client manager and see wether your wireless card been picked up, if that failed try clicking other question marks & re-installing then. It may be related.
8/13/2009 6:49:21 AM • Buffalo... • Answered on Aug 13, 2009
Client Manager will not pick up my buffalo wireless card.
You can find the driver in the Buffalo download archive for older products:
http://site2.buffalotech.com/support/downloads2.php
Choose from the menu.
You also find manuals and set-up guides there.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
8/5/2009 6:13:00 AM • Buffalo... • Answered on Aug 05, 2009
Can't install client manager from buffalo
what are you trying to install ? you may want to run the installalation using the "Run as..." command
6/12/2009 5:40:25 AM • Buffalo... • Answered on Jun 12, 2009
Buffalo airstation router
If the power went out...it could have serged the router...try holding in the reset button for 30 sec....if no luck there take the router back where you purchased it and tell them it is faulty and needs replaced.
11/11/2007 5:09:44 AM • Buffalo... • Answered on Nov 11, 2007
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
9/20/2007 8:27:11 AM • Buffalo... • Answered on Sep 20, 2007
2answers
Buffalo wireless router
you may need to dissable your wired lan adapter as it will be looking to assign the same ip address and you need it to assign to your wireless adapter. Asuming your router is wireless enabled as some are not be default and make sure your router has DHCP enabled to automatically assign ip addresses to your pc,s
9/17/2007 3:47:25 PM • Buffalo... • Answered on Sep 17, 2007
tip
The Unseen Dance of Pixels: Decoding the Enigma of Display Advertising
In the dazzling kaleidoscope of the digital universe, where every pixel holds a potential story, display advertising emerges as a silent choreographer, orchestrating a dance of colors, wit, and strategic finesse. It's not just about selling a product; it's about creating an experience, a visual ballet that entrances the audience. Join us as we unravel the cryptic elegance of display advertising, where pixels pirouette, and words waltz across screens. https://www.sot.com.pk/ Pixelated Ballet: Crafting an Overture of Visuals Picture this: pixels as dancers, gracefully moving across the canvas of the internet, creating a visual overture that demands attention. Display advertising isn't a static image; it's a pixelated ballet, a dance of dynamic banners, interactive animations, and eye-catching visuals. The challenge lies in transforming these pixels into performers that capture the audience's gaze amid the digital spectacle. Colors become the prima donnas, each hue chosen with purpose - evoking emotions, setting tones, and telling stories without uttering a single word. It's a visual feast where every pixel contributes to the narrative, and the canvas becomes a stage for creativity to unfold. Whispers of Persuasion: The Ballet of Words Beyond the visual spectacle, the words accompanying the dance are the whispered secrets that guide the audience through the performance. Display advertising is not just a showcase; it's an intimate conversation in the midst of a crowded ballroom. The language used must resonate, connect, and persuade, transcending the boundaries of pixels and reaching into the hearts of the audience. Crafting a compelling copy is akin to choreographing a dance of words - a delicate balance between information and intrigue. The human touch comes alive as the words weave a narrative that doesn't just sell but invites the audience to join the dance. Strategic Choreography: Placing Pixels in the Spotlight In the grand ballroom of the internet, strategic placement becomes the choreographer's signature move. Display ads need to pirouette into the limelight where the audience is most receptive, whether it's on social media stages, niche websites, or the center stage of search engine results. Retargeting becomes the encore, a chance for pixels to reprise their performance for those who missed the initial act. It's a strategic dance move that whispers, "You're not just an observer; you're part of the performance." The stage is set, the spotlight is on, and the dance of pixels continues. https://smdscreens.com.pk/ Metrics: Applause or Encore? Every dance seeks applause, and in the digital realm, metrics serve as the standing ovation. Click-through rates, conversion metrics - these are not just numbers; they are the applause that reverberates in the virtual auditorium, confirming the success of the performance. Metrics are the audience's way of saying, "Encore!" or "Bravo!" - insights that guide the choreographer in refining their moves for future acts. Conclusion: The Unending Enchantment of Display Advertising In this enigma of pixels, words, and strategic maneuvers, display advertising emerges as an unending enchantment. It's a dance that evolves with technology, embraces creativity, and adapts to the shifting rhythms of consumer behavior. As you embark on your display advertising journey, remember - you're not just an advertiser; you're a choreographer, weaving a spellbinding performance that resonates long after the curtain falls. So, let the pixels dance, and the words waltz, as you navigate the unseen choreography of display advertising. In this digital ballroom, you're not just crafting ads; you're orchestrating an experience, leaving the audience in awe, and ensuring that the dance of pixels remains etched in the memory of those who witness its captivating elegance.
/uploads/images/whatsapp image 2023-10-10 at 16.57.30-undefined-undefined-1.jpeg
I/O error on Buffalo HD-PET500U2 Ext Hard Drive
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output (I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
10/4/2018 8:14:57 AM • Buffalo... • Answered on Oct 04, 2018
0answers
Buffalo Technology Buffalo AirStation Broadband Router AP Wireless (WBR-G54) Logo
26 questions posted
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Buffalo Technology Computers & Internet
Most Popular Question
client manager will not pick up buffalo
  • Computers & Internet
