20 Most Recent Logitech K120 Keyboard Questions & Answers
I have just bought the K120 Logitech Spanish keyboard. The keys don't match what comes up on the computer screen. What a waste to time and money. Wish I had kept to the English keyboard or b ough
The operating system controls what language comes up on the screen, not the keyboard. A keyboard is just a bunch of switches with letters printed on them. The computer only sees a switch closing that is supposed to represent a letter that it is programmed for. Your operating system may be able to operate with more than one language or you may have to buy an operating system designed for spanish.
9/29/2014 4:11:05 PM • Logitech K120... • Answered on Sep 29, 2014
2answers
Logitech wireless combo mouse keyboard mk220 support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries. • Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse. • If the USB receiver is plugged into a USB hub, try plugging it directly into your computer. • Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface. • Restart the computer. • If these suggestions don't work, download the Reconnection Utility from http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM • Logitech... • Answered on Feb 28, 2024
Does the Logitech cordless mouse have data in it
Of course not. It is a simple I/O (input output) device. It stores no data. ..
2/3/2024 5:55:00 AM • Logitech... • Answered on Feb 03, 2024
How i can connect my logitech wireless mouse EN60950 to the laptop
Unfortunately, EN 60950 is not a Logitech model number. It indicates that the mouse (or other electronic product) was tested and met the European IEC 60950 standard. Here's a copy of a Logitech EN60950 certificate: https://www.logitech.com/images/pdf/compliance/AGY-700-018651.001_AGY%20CERT%20CB%20HS%20A00086%20BAER%20CI%20(GGEC)_EUROPE.pdf . Logitech sells several different wireless mice types. Some connect to Bluetooth only. Some connect with a specific USB wireless transmitter/receiver. The dongle is small enough to fit inside the mouse's battery compartment or stay in a USB port when the laptop is moved. (Older Logitech devices used the Unifying USB wi-fi adapter; new ones use the Bolt adapter.) A few models can be used with both Bluetooth and one of the wireless adapters. These can connect to two or more devices and then a single button switches between devices. Please try to find the actual model of the mouse to get the correct information for connecting the mouse. Logitech support may be able to sell you the USB dongle if they have the correct one in stock. I hope this helps. Cindy Wells
12/8/2023 11:47:00 PM • Logitech... • Answered on Dec 08, 2023
Need help with Logitech DiNovo keyboardmodel Y-RAY81 that is not flashing green light when put it on the charging base.
When charged, the green light does not flash. However, since you mentioned that the old battery is also not flashing any light, it could indicate that there might be some issues with the charging base or the keyboard itself. Here is a link to some troubleshooting steps to take. But if they do not work, your next step is to contact Logitech support. Troubleshoot keyboard connection issues - Logitech Support + Download
10/29/2023 11:39:54 AM • Logitech... • Answered on Oct 29, 2023
Can change tastature with cyrillic character with another tastature with normal character from the same model of keyboard?
The PCBs will be the same, the language and therefore what the keys type comes from the computer software that is chosen. The hardware keyboard is the same, just different printing on the keys.
8/7/2023 4:48:09 PM • Logitech... • Answered on Aug 07, 2023
2answers
LOGITECH SQUEEZEBOX STOPPED WORKING
Return it to the maker for repair or find a local audio tech. https://www.google.com/search?q=LOGITECH+SQUEEZEBOX ..
3/18/2023 1:31:51 AM • Logitech... • Answered on Mar 18, 2023
I took off a couple of keys from my Logitech K520 keyboard but after reinstalling them, they do not work correctly.
I have ruined 3 keyboards taking them apart trying to clean them. Just replace the keyboard, they are a disposable item and don't last forever. If you can find a Cherry Brand keyboard, they are the best quality. Mine is over 20 years old.
2/22/2023 7:16:53 PM • Logitech... • Answered on Feb 22, 2023
My logitech keyboard K330 DOES NOT have a connect button on the bottom! There are just 13 screws and 3 tiny pinholes.
have you installed usb receiver? I have installed several keyboard and mouses, they all connected aytomaticaly copy and paste https://www.logitech.com/assets/50388/wireless-combo-mk330-quickstart-guide.pdf ..
2/11/2023 5:45:27 PM • Logitech... • Answered on Feb 11, 2023
How do I add format to my logitech 650I downloaded from my old logitech to my new logitech and it doesn't have the format button on it
It sounds like you are trying to use the same formatting settings on your new Logitech keyboard that you had on your old Logitech keyboard, but the formatting button is not present on the new keyboard. To add the formatting button to your new Logitech keyboard, you will need to do the following:
  1. Open the Logitech Options software. This software allows you to customize the settings and functionality of your Logitech keyboard.
  2. Select the "Buttons" tab. This will allow you to customize the buttons on your keyboard.
  3. Find the formatting button that you want to add. Depending on the model of your keyboard, you may have the option to add a variety of formatting buttons, such as bold, italic, and underline.
  4. Assign a function to the button. To add the formatting button to your keyboard, you will need to assign a function to it. Click on the button and then select the formatting function that you want to use.
  5. Save the changes. Once you have added the formatting button and assigned a function to it, click the "Apply" button to save the changes.
I hope this helps! Let me know if you have any other questions.
1/2/2023 12:12:25 AM • Logitech... • Answered on Jan 02, 2023
Simple bluetooth support for logitech keyboard Y-raj56a?
Unfortunately, Logitech does not offer any Bluetooth support for the Logitech Y-RAJ56A keyboard. The keyboard is designed to be used with a wired connection, and it does not have any Bluetooth capabilities. Yes, you can use a Bluetooth adapter to connect your Logitech Y-RAJ56A keyboard to a Bluetooth enabled device. However, you should bear in mind that the keyboard will not have any additional features or support when connected via Bluetooth. So you will need to purchase a Bluetooth adapter. The Kinivo BTD-400 Bluetooth 4.0 USB Adapter is a good choice and is compatible with most versions of Windows and Mac. P.S. BTD400 Advisory A recent update to Windows is preventing the BTD-400 from locating drivers automatically when plugged in for the first time. Please visit the article below to set up the BTD-400 Bluetooth Adapter for the first time. BTD400 Driver Installation
12/31/2022 12:10:44 PM • Logitech... • Answered on Dec 31, 2022
Water damage in Logitech Ultra Thin i5 keyboard.
12/15/2022 1:39:40 AM • Logitech... • Answered on Dec 15, 2022
I have Logitech G502 Mouse why It cannot run automatically in my PC
it you forget something that must install on your PC to operate your Mouse G502. Just get logitech g502 software first, then install it to your PC
10/15/2022 3:22:48 AM • Logitech... • Answered on Oct 15, 2022
Logitech cordless headphones model #A-00006 has problem with left side can't hear any support
Most likely it's a programming thing but it could be you have a loose wire... Never no.. Mite try getting a cheap pair try to see if the same problem occurs.. Thanks good luck
9/8/2022 7:28:39 AM • Logitech... • Answered on Sep 08, 2022
Logitech itouch keyboard on windows 10
yes.
5/6/2022 1:18:16 PM • Logitech... • Answered on May 06, 2022
2answers
I am looking for a Dongle
google Logitech M-R0013 receiver for more info they start at $5.00
5/6/2022 1:06:16 PM • Logitech... • Answered on May 06, 2022
Need Win7 driver for Logitech Webcam 861092-0020
Try Logitech but don't hold your breath because win7 is obsolete and no longer supported.
11/7/2021 1:19:40 PM • Logitech... • Answered on Nov 07, 2021
Logitech K120 Keyboard Logo
6 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
just bought k120 logitech spanish
  • Computers & Internet
