20 Most Recent
Mustek TwainScan 600 III EP Plus Flatbed Scanner Questions & Answers
How to install
Requires a ATAPI driver to be downloaded from the manufacturer website - then some application to import the image from the scanner. This can be Photoshop, Microsoft Word, Adobe Writer etc.
Drivers for scanner
http://mustek.com/product_resources/drivers/scanner/parallelport/600IIIepplus/win31-95-nt/63EP322.EXE
Tipos de conectores para Power 120v - 15 volt
Mustek 600 III EP Plus scanner, it doesn't matter what is the adapter input voltage is (base on your local country power supply voltage), but as long as the adapter output plug in your scanner is +15VDC/1A Positive Polarity (positive inside and negative outside), then your scanner will work.
Flatbed scanner
take a volt meter and check the power at the end of the power adapter, sounds like it may be a power issue. if all is ok on that end does it still work on the old system? you may have to hook it back up to a working system and see if there is a firmware upgrade for it. Best of luck
Drivers are available from the mustek web site in US or Taiwan. See http://www.mustek.com.tw/Download/driv_scanr/english/600iiieplus.html.
You need an AC power adapter if you don't have one. The original was an YHI Power Adapter, model YC-1015-15, Input 100-120V, 60 Hz, 0.4A, Output +15VDC/1A. I know because I'm reading it off of mine (I am the original owner of one, this is about 10 years old). You can find new ones on eBay for $10 plus shipping.
Finally, you need a cable that connects the scanner to the PC using parallel port technology. Both ends are 25 pin Female, and the cable itself is marked as IEEE 1284 compliant. Cable is AWM E101344 Style 20276 30V VW-1 Space Shuttle. Must have 25 pin female connectors, check eBay or http://www.driverforum.com/controller5/10421.html.
Mustek scanner Hang up
Hi leon,
Re-install again the driver of your scanner, machines hangs up because of the operating system got a problem working with it.
Enjoy
tnx
-micro
Is ther a driver vor Mustek P3600 A3 Pro for Windows 10?
Yes, there is a driver available for the Mustek P3600 A3 Pro for Windows 10. The driver can be downloaded from the official Mustek website [1], or from the Windows Update tool [2]. Once the driver is installed, it is important to keep the drivers updated in order to maintain the functionality of your computer [3]. Additionally, using a driver updater such as DriverDoc can be beneficial in keeping all of your PC drivers updated [2].
<b>References:</b>
<span>[1] <a href='https://www.mustek.de/drivers/index.php?stap=3&category=Scanners&product=p3600_a3_pro' target='_blank' class='text-purple-1 underline'>Scanners > P3600 A3 PRO - Mustek Driver & Support</a></span>
<span>[2] <a href='https://www.solvusoft.com/en/update/drivers/scanner/mustek/p-3600-a3-pro/sub-models/' target='_blank' class='text-purple-1 underline'>Mustek P 3600 A3 Pro Drivers Download - Scanner - Solvusoft</a></span>
<span>[3] <a href='https://www.driverscape.com/download/p3600-a3-pro-wia-scanner' target='_blank' class='text-purple-1 underline'>P3600 A3 Pro WIA Scanner Drivers Download</a></span>
Written by Chatsonic
