20 Most Recent Aprilaire 400 Humidifier Questions & Answers
Keep blowing 24V transformers
Somewhere in the mess you have described there is a short that is compelling the transformer to put out more current than what it is designed for. It gets hot, really overheats, insulation melts, and the wires melt. Ergo blown transformer.Problem is with whatever that unit is plugged into/powering..
3/3/2017 2:04:11 AM • Aprilaire 400... • Answered on Mar 03, 2017
Aprilaire 400 - Mesh Screen not wet
Not happy either. I bought 3 Aprilaire 400 for my house (3 zones). I picked this style since I have attic installation and did not want to run drains. The first night I expected a major air quality improvement but no change in humidity. I have installed humidifiers before so I know the drastic improvement they make. So I watched for a season and still no humidity improvement. Absolutely nothing at all. Same exact observation as you all described. Only the bottom of the media was wet. I'm dissatisfied with Aprilaire 400. Do not buy! Since I installed humidifiers before and understand them I am converting the Aprilaire 400 to work like a Aprilaire 600. I simply unwired the float sensors, removed the floats/lid and using a knife cut some of the plastic cups so the water would drain well. I also cut open the plastic exit port some too so it wont clog from dust globs. I obviously added drains. HUGE RESULTS. On the very first cycle on the humidity in that zone went from 25 to 48. I am watching carefully. -GK
12/11/2016 11:32:37 PM • Aprilaire 400... • Answered on Dec 11, 2016
2answers
How to install an Aprilaire 400 humidifier
Here is a installation guide http://electronicaircleaners.com/database/documents/aprilaire_400_installation.pdf
7/8/2014 3:46:03 AM • Aprilaire 400... • Answered on Jul 08, 2014
If i hook my Aprilaire 400 Manual (not auto/digital) humidifier up straight to a 24v wall outlet instead of to the furnace, will it still work correctly? Or does it need to be powered by the furnace t
Your humidifier is a bypass type. The only voltage needed is 24vac to open the water valve. Air only flows through the humidifier when the furnace blower is running, and the wet pad will add very little humidity if the furnace is not running and heating the air before flowing through the wet pad in the humidifier. It is best the water valve is only energized when the furnace is running. Some furnaces have a connector on their control boards labeled HUM for this purpose. Test it's voltage when the furnace is running because some will output 110vac instead of 24vac you need.
7/8/2014 3:43:08 AM • Aprilaire 400... • Answered on Jul 08, 2014
Humidistat makes clicking sounds
This may caused by a weak solenoid or loose wiring comncetions to the solenoid. Make sure all wiring connections to humidifier amd solenoid are tight and secure.
1/17/2013 4:06:13 PM • Aprilaire 400... • Answered on Jan 17, 2013
After a few hours my Aprilaire 400 makes a constant clicking sound that won't stop. Is it the solenoid?
This is either the solenoid or a loose low voltage wire. Make sure all the wiring connections are tight, if they are the solenoid if bad and will need to be replaced.
12/15/2012 4:44:00 AM • Aprilaire 400... • Answered on Dec 15, 2012
Replace water panel
Hello, if your asking how to replace the water all you need to do is buy a replacement water panel, and make sure the side with the black mark is pointing up.
12/14/2011 12:36:42 AM • Aprilaire 400... • Answered on Dec 14, 2011
Not getting water into the unit and the unit is
Hello, check to see if you are getting 24 volts to the solenoid valve, if you are and the solenoid does to click to let the water in it must be replaced. If you are not getting 24 volts start at the transformer and work your way toward the solenoid valve to find where the voltage stops.
2/26/2011 12:41:48 AM • Aprilaire 400... • Answered on Feb 26, 2011
We noticed the humidity went down to 30% and I
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
1/27/2011 9:29:18 PM • Aprilaire 400... • Answered on Jan 27, 2011
Air inside house feels dry. Not sure if humidifier
Sounds like you are not getting the proper voltage to the solenoid valve...
Check for 24v coming off of the transformer...that may be 24vac not vdc...
Then check to see if there is power coming from the humidistat...
unhook the wires to check for the power at the solenoid valve...
check across the two wires...
if there is power the valve is bad and that alone will cost about 90 bucks with shipping...
if there is no power trace back and see where the power stops at...
heatman101
1/20/2011 12:38:40 AM • Aprilaire 400... • Answered on Jan 20, 2011
Water not going into the humifier
The first thing to check is if you are getting 24 volts to the solenoid valve, if you are and it is not opening to let the water in then u need a new solenoid vlave. If you are not getting 24 volts check to see if you are getting 24 volts at transformer, if not then turn off power to to the transformer and check itls continuity on the secondary side, if no continuity then the transformer must be replaced. Also make sure the saddle valve is open and that the inlet strainer at the solenoid valve is clean and no sediment is built up in it restricting water flow.
1/19/2011 6:48:54 PM • Aprilaire 400... • Answered on Jan 19, 2011
I have a aprial air 400a. I have aready checked
I don't really have a "solution" but you might want to check the resivoirs for lime/calcium buildup as they can defeat the signal by the sensors thinking that the system is full of water. Some vinegar and a toothbrush resolves this. The other possibility is that your sensors may be deflected below (not in contact with) the resivor bottom.
1/18/2011 7:24:04 PM • Aprilaire 400... • Answered on Jan 18, 2011
Aprilaire 400 humidifier. No water flowing to the
Check to see if you are getting 24 volts from the transformer, if not, turn off power to the transformer and check the resistance of the secondary side, if no resistance the transformer is bad and need to be replaced. Also check to make sure all the wires are secure. If you are getting voltage at the transformer then bring power directly from transformer directly to solenoid valve and it should click open and let the water through, if it does then either the sailswitch/current sensing relay is bad or humidistat is bad.
1/17/2011 9:06:32 PM • Aprilaire 400... • Answered on Jan 17, 2011
Aprilaire 400 Humidifier Logo
Popular Tags
43 questions posted
Top Aprilaire Humidifiers Experts
Paul Carew
john h
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Aprilaire Humidifiers
Most Popular Question
humidistat makes clicking sounds
  • Humidifiers
