20 Most Recent MSI FX5200-T128 (128 MB) Graphic Card Questions & Answers
3answers
TFT screen not working
hi
clean your vga ,fix it in your agp slot also remove dust from it .
reconnect all cable to board.also clen processor case.
clear your bios.
take away cmos cell for 15 minutes.
3/18/2015 11:17:06 AM • MSI FX5200-T128... • Answered on Mar 18, 2015
0answers
0answers
4answers
Geforce fx5200 t128 latest drivers
You can download your drivers from:
http://www.nvidia.com/object/winxp_169.21_whql.html
Good Luck!
10/18/2013 2:14:59 PM • MSI FX5200-T128... • Answered on Oct 18, 2013
I need a driver for fx5200-t128 (win 7)
Thank you for visiting Fixya!
Device Drivers
There is a download for this card:
http://driverscollection.com/?file_id=22853
If this download does not work for Windows 7
You can use Device Manager and/or Windows Update to locate the necessary driver for your system. If you know the manufacture of the hardware in question you can visit their respective website and obtain the driver from there.
Also, feel free to visit this help article found on the Windows Help and How-to website about Tips for fixing common hardware problems.
How to update drivers using Windows Update
1. Click Start, click All programs, then click Windows Update.
2. If prompted press Continue or provide administrator credentials.
3. In the left pane, click Check for updates.
4. To see if updated drivers are available, click View available updates.
5. Windows Update will list any updated drivers that are available under Optional downloads.
6. If any updates are available, click the driver that you want to install, and the click Install.
How to manually update drivers using Device Manager in Windows
1. Click Start, right-click Computer, and select Manage.
3. In the left pane, click Device Manager.
4. In the middle pane you will see a list of categories for installed hardware.
5. Check for any devices that have a yellow warning icon.
6. Right-click that particular device entry, and select Update Driver Software.
7. If you have already downloaded the driver select Browse my computer for driver software.
a. Specify the location of the driver you downloaded and follow the on-screen instructions.
8. If you have not already downloaded the driver you can have Windows search online.
a. Click Search automatically for updated driver software, and follow the onscreen instructions.
11/23/2012 8:42:49 AM • MSI FX5200-T128... • Answered on Nov 23, 2012
3answers
Is MSI FX5200-TD128 compatible with
Thanks a million!! This driver worked perfectly for the MSI FX5200-TD128 graphics card in Windows 7.
9/21/2012 7:14:58 PM • MSI FX5200-T128... • Answered on Sep 21, 2012
I need to down load my driver graphic card (inno3d
go through the link given below downloading will be automatically started install the drivers and you are done..
http://in.download.nvidia.com/Windows/175.16/175.16_geforce_winxp_32bit_english_whql.exe
12/30/2010 2:01:43 PM • MSI FX5200-T128... • Answered on Dec 30, 2010
I need a drive for T128-M MP3 player that will load in Windows XP
Hello
Do you mean the driver for the device that came with windows 98 will not work on XP?
If so, all you need to do is to go to MSI's website and download the XP drivers for your graphics card. Hope this can help you.
Kind regards
Andrea
11/6/2009 12:49:55 AM • MSI FX5200-T128... • Answered on Nov 06, 2009
2answers
MSI FX5200-T128 :: Hard-Freeze
You could try using the driver for the FX5200 directly from Nvidia. Maybe the MSI drivers are causing the issue. If not try using the video card in another computer and see if it works. Without testing the card or the board it is hard to say. Sometimes a weak powersupply can cause problems like this. Also make sure if there is a power connection to the video card that it is hooked up. Some video cards need additional power plug hooked up.
9/11/2009 5:13:08 AM • MSI FX5200-T128... • Answered on Sep 11, 2009
[email protected]
http://www.nvidia.com/object/winxp_175.19_whql.html
The driver for your FX5200 Video card, Also known as Nvidia FX5200
El conductor para tu tarjeta video FX5200, también conocido como Nvidia FX5200
¡Clasificar por favor este FixYa! gracias
9/16/2008 1:06:25 AM • MSI FX5200-T128... • Answered on Sep 16, 2008
Opengl
u should update ur graphic card driver or ur computer is too old to run that game.
9/15/2008 3:56:33 PM • MSI FX5200-T128... • Answered on Sep 15, 2008
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
MSI FX5200-T128 (128 MB) Graphic Card Logo
Popular Tags
16 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
msi fx5200 td128 compatible
  • Computers & Internet
