20 Most Recent NAD 7250pe Stereo Receiver Questions & Answers
This is the technical solution, you have to open the unit:
Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.
The unit will then boot up in factory default.
Henrik Pedersen
NAD Audio... | Answered on Oct 29, 2019
Hi Michael, check inside your NAD C542, there are 4 fuses, check that none is open, if all are well, you could have problems with the capacitors in the area of the power supply or in the case of the Transformer
If you do not have technical capabilities to evaluate the above, consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, revisa en el interior de tu NAD C542, hay 4 fusibles, controla que ninguno se encuentre abierto, si est?n todos bien, podr?as tener problemas con los capacitores del ?rea de la fuente de alimentaci?n o en el pero de los casos el Transformador
Si no tienes capacidades t?cnicas para evaluar lo previamente indicado, consulta un servicio t?cnico especializada
Espero puedas resolver el problema
Saludos Franco Dosil
http://diagramas.diagramasde.com/audio/NAD-C542-Service-Manual-Schematics.pdf
NAD Audio... | Answered on Sep 16, 2019
Check the rectifier diodes in the power supply for shorts and look at all the filter capacitors in the power supply. Look for puffy discolored and domed tops. All filter capacitors must have flat tops. Check the windings of the transformer for darkened or burnt spots and test for shorts in both the primary and secondary windings
NAD Audio... | Answered on Jul 24, 2019
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
NAD Audio... | Answered on Jun 22, 2019
If the take up spool stops taking up the tape, it wraps itself around the capstan and jams up the mechanism.
NAD Audio... | Answered on Apr 11, 2019
If the speakers are all good and wiring too, then it's likely that a fault has developed in the main amp section. Till this is cleared the protection will not go away.
NAD Audio... | Answered on Mar 06, 2019
Did you make sure that the wiring is correct? did you make sure its +12V and ground and not the opposite way? If you checked that, please remove the remote wire for testing. If it then doesn't work, remove the wires from the speakers from it and try again. If it still doesn't do anything, bring it to a repairshop.
NAD Audio... | Answered on Jan 16, 2019
Even Google translate can't translate this. We are a North American website, we only speak English.
NAD Audio... | Answered on Oct 25, 2018
Could be an open internal fuse, power supply failure, or power switch failure
NAD Audio... | Answered on Oct 15, 2018
NAD 7250pe Stereo Receiver Logo
1 questions posted
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • NAD Audio Players & Recorders
Most Popular Question
nad c542 cd player not turn problem
  • Audio Players & Recorders
