20 Most Recent Samsung Wave 3 S8600 Questions & Answers
Samsung s8600 charging ways
Without charging ic. Jumper for charging
10/15/2016 4:16:31 AM • Samsung Wave 3... • Answered on Oct 15, 2016
0answers
My mobile goes of and on by itself continously unless i remove the battery. and i am quite sure that it has a software problem. i tried to solve this through kies but no help coz my computer cannot re
Due to the phones software not being compatible KIES wont help unfortunately. That is why you can't even get whatsapp or bbm on these phones due to the software not being compatible.
4/29/2014 7:02:47 AM • Samsung Wave 3... • Answered on Apr 29, 2014
I have samsung wave 3(gt8600) that switch off itself and switch on itself without stopping. It will stop only when i remove the battery. I treid to solve through samsung kies but nothing helps me why
Hi there, this is a problem with all the Wave 3's, it's quiet dissapointing as there software cannot cope. The only way I managed to fix mine was by deleting unwanted items so as to reduce the memory and then let the battery run totally flat and recharge it over night. It seems to hold out for a good few weeks after that but unfortunately does start doing it again. Hope that help's a little.
4/8/2014 2:07:06 PM • Samsung Wave 3... • Answered on Apr 08, 2014
My mobile goes off and on by itself
Hi there, This is a common problem with these phones. I let my battery totally run down then charge it again fully, most of the time this seem's to help and can go days sometimes a week or two without that happening again. Doesn't look like there is any total fix for this problem. Try it see if it works for you. Regards
4/2/2014 8:27:53 AM • Samsung Wave 3... • Answered on Apr 02, 2014
Samsung unlock code
Hi, What kind of lock it is? IF it is a network lock, You need to specify the respective network's name and country too. You can visit www.Unlock-Zone.Com and submit the required credentials to get the accurate unlock code for your Samsung Wave 3 S8600 at affordable cost with free unlocking instructions. Good luck mate.
1/9/2013 10:29:54 AM • Samsung Wave 3... • Answered on Jan 09, 2013
How do I connect my YAMAHA RX-V493 audio/video receiver to my Samsung UN65HU8550F TV?
On the rear of your TV connect, with a phono/RCA cable to the Audio R + L sockets, connect the other ends to your Yamaha using the TV in sockets. See photos attached screenshot 2024-04-05 at 20.45.20-undefined-undefined-0.png screenshot 2024-04-05 at 20.43.54-undefined-undefined-1.png Hope that helps. HDMI is for video unless the extra pins are added for audio.
4/5/2024 7:49:49 PM • Samsung Audio... • Answered on Apr 05, 2024
How to fix my samsung YP-U4 mp3 no screen display
See page no 65 troubleshooting in user manual YPU4J-CANADA-ENGLISH0.0_0610.indd (samsung.com)
1/10/2024 12:18:19 PM • Samsung Audio... • Answered on Jan 10, 2024
Frozen screen on my old samsung yp-tyj mp3 player.
See following link, it may resolve your issue My MP3 Player Is Locked Up (Frozen). ' Samsung Africa
12/28/2023 12:46:59 PM • Samsung Audio... • Answered on Dec 28, 2023
Pairing Samsung remote to Yamaha RX-V361
Normally makers don't play ball between each other. Yes if it was a Samsung Television and a Samsung Receiver A/V System. Or if you have something like a Cable Box or Satellite System that is made to interact with other makes. Or if it is a Universal Remote. I think you were just lucky that it happened to use the same frequency. Look in the manual for a scan command. https://www.google.com/search?q=Connect+Samsung+OLED+S90+remote+to+Yamaha+RX-V361+via+optical ..
12/20/2023 12:35:03 AM • Samsung Audio... • Answered on Dec 20, 2023
My Samsung yp-s3 won't open without connecting to the power supply or power bank
Check the battery. It may require replacement.
12/19/2023 2:02:55 PM • Samsung Audio... • Answered on Dec 19, 2023
Is it compatible with other phones apart from the iPod?
You would have to define 'it'. In a question talking about two items, you need to clearly state 'make model (what it is)' for both items. The main item should be the first 3 words in the question. ..
9/12/2023 6:01:10 PM • Samsung Audio... • Answered on Sep 12, 2023
2answers
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try: 1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted. 2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected. 3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound. 4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals. 5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured. 6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged. 7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker. 8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings. 9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues. 10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device. 11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue. 12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality. 13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair. Remember to refer to your device's user manual for specific instructions related to your model.
8/29/2023 9:05:03 PM • Samsung Audio... • Answered on Aug 29, 2023
2answers
Part is missing pls help me what part number of this transistor this is from samsung home theater HT-330K thanks in advance
Service Manual. Page 5.2
SAMSUNG HT-E330K Service Manual download, schematics ...
elektrotanya.com > download
Translate this page Download SAMSUNG HT-E330K service manual & repair info for electronics experts.
Home Entertainment System HT-E330K ' Samsung Support ...
www.samsung.com > ... > Standard home cinema system
Mar 18, 2020 - Home Entertainment System HT-E330K. Solutions & Tips, Download Manual, Contact Us. Samsung Support Singapore. Missing: schematic ‎' Must include: schematic
8/26/2023 9:36:43 AM • Samsung Audio... • Answered on Aug 26, 2023
I have a vintage Samsung midi hifi 7450 used daily. But the record deck has suddenly stopped turning.
The platter drive belt needs replacing. Platters normally lift off, sometimes there is a c-clip.https://www.google.com/search?q=samsung+midi+hifi+7450+drive+belt+replacement..
8/11/2023 4:34:35 PM • Samsung Audio... • Answered on Aug 11, 2023
Samsung Wave 3 S8600 Logo
16 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
samsung s8600 charging ways
  • Audio Players & Recorders
