20 Most Recent
Toshiba 50L5200 50-inch LED TV Questions & Answers
What is the remote code for an rca model detk156r tv? for dish tv
I know the problem well. Try to google/amazon your tv model. Go to the page wherever it is being sold and check out user reviews. Someone may have posted the code (I did it once for my DirecTV) and got a ton of "thanks"
If not, write a review and ASK if anyone knows the code you need.
How to use Toshiba Media Player
Is the USB drive able to be read on your PC / Laptop ?
It COULD be that the USB drive has been 'Formatted' (made ready to receive files) but not in the 'FAT32' mode. It WILL say so in your TV manual.
PCs can read all format USB sticks but TVs are fussy and generally only work if the USB stick is formatted 'FAT32' and not 'NTFS' (which it probably is.
1) Put the stick in your PC - right click on it from 'my computer.'
2) Format the USB drive with FAT32,
3) Reload the stick from your PC with the photos.
4) Plug it in your TV.
It will be fine.
Toshiba 32LV67U audio receiver code.
:It is possible that your TV is not compatible with the Xbox, or that you may need to enter a specific code. I suggest checking the manual for your TV to try and find the audio receiver code, as well as searching online to see if there are any additional instructions on how to connect it to the Xbox. Additionally, you may want to contact the manufacturer of your TV or Microsoft for further assistance.
I have a Toshiba Laptop
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
