20 Most Recent
Lg800g With 1200 Minutes And TripMinutes For Life tracfone Questions & Answers
How do you change language
On the home page tap the dice icon then the gear icon. Select the second item on the menu (Phone or Telefono). Select the second item on the menu (Language or Idioma). Select the language of your choice.
Icons on the home page
Tap the white-on-blue up-arrow near the lower-left corer of the screen, then drag the unwanted icons to the icon bar at the bottom of the screen. When done, tap the white-on-blue down-arrow at the upper-left corner.Bear in mind that not all icons can be removed from the home screen.
How do I transfer pictures from my phone to the computer
Plug the Usb/sync cable into your Windows PC, turn on the phone.Your computer should prompt you found new "Removable device"Open the new device,locate your picture right click the desire picture then choose copy/cut then paste picture to you desktop..hope it helpscheers
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
