20 Most Recent Mitac GETAC A 320 Notebook Questions & Answers
Need a network adapter driver
just download this software,no need search engine,no more tired of looking anywhere...instantly,it will be in your laptop for several minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
hope this solution helps,you can comment and rate for satisfaction....thanks
5/26/2020 3:31:06 PM • Mitac GETAC A... • Answered on May 26, 2020
2answers
I need a sound card for my hi-grade note book 8615p
That may be a problem. Most Laptops have integrated audio.
1/18/2013 2:40:23 PM • Mitac GETAC A... • Answered on Jan 18, 2013
0answers
GRIVERS
Welcome to fixya
Please let me know the specific drivers that you are looking for and I can give you links on where you can download them
Hope to hear from you
7/19/2011 4:06:51 PM • Mitac GETAC A... • Answered on Jul 19, 2011
DRIVERS
In general, you can find MITAC drivers here:
Not sure which ones you're looking for though.
7/19/2011 2:28:23 PM • Mitac GETAC A... • Answered on Jul 19, 2011
Hi there,Does anyone know why an Hi-Grade 8615
This laptop is made by Mitac and sold by many computer companies (in the UK at least) such as Hi-Grade, Evesham and Medion.
This has a common fault which is being found on more and more laptop computers these days and that is that the video chip overheats due to lack of cooling and the cheap (WEII Compliant) lead free solder that is used to fix it to the motherboard cracks.
Common signs of this fault can be one or more of the following-
No Power light when charger connected
Battery not charging
Internal fan not running
And of course no picture
Repairing it is difficault. If you remove the bottom panel you will see a silver heat sink half under the plastic edge (this could so easily have been connected to the CPU heatsink arm and this of been avoided!). If you apply some light pressure to the top of it and switch your machine back on it usually will boot.
If it does and you want a fast fix then wedging some card between the top of the sink and the plastic casing may keep it alive for a while longer. If on the other hand your a pro or feel it's shi t or bust time then get a blow lamp and (like walking over broken glass) carefully heat the chip to reflow the solder beneth it. Do not apply any pressure to it when hot as the solder it is connected with is designed to be about 1mm from the motherboard surface. Pressing it will look like you have bitten into a hot dog and the mustard has spurted out both ends, except obviously with solder and a GPU (not so tasty!)
I shouldn't have to mention this but some people arn't so bright so please don't take offence: Remove the motherboard along with any cables, ram and the processor before attempting the blow lamp method!
It is actually professionally done this way except with a 'Rework Station) and not a blow lamp! I have however done it with an electric blow lamp I bought from Argos for £12 several times on various machines with all but one failing to revive.
Just as a note, the Xbox 360 RROD (Red Ring Of Death) is caused by the same issue. It can also be repaired using this method although there are safer alternatives in that case.
Hope I have helped some of you anyway. Please rate to let me know.
Phill.
10/7/2010 1:34:37 AM • Mitac GETAC A... • Answered on Oct 07, 2010
Mitac 8060b screen is really
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
9/18/2010 10:14:14 PM • Mitac GETAC A... • Answered on Sep 18, 2010
MITAC X-200/12V POWER SUPPLY wont turn on
that is a PSU, PC desktop , the bench test is easy 1 jumper it is old, and old 20 pin power plug not used in decades just 13 to 14 20 pin version https://www.pcdied.com/PSU/power.html#the_jump_start_magic hear fan spin in PSU see all pins go hot at spec voltage using a voltmeter
3/27/2022 10:50:53 PM • Mitac Computers... • Answered on Mar 27, 2022
2answers
My mitac not start
what is it, posted to computer repair help is too hard to tell what it does first? animal vegetable mineral?>(classic joke) the only clue is start, (cards starts, boats and plains or anything with and engine) that? the dictionary shows this. omg. list Acronym Definition MITAC Mining Industry Training and Adjustment Council (Canada) MITAC Major Industries Training Advisory Council (Darwin, Northern Territory, Australia) MITAC Map Interpretation and Terrain Analysis Course MITAC Microcomputer Tactical (aid) MITAC Marine Industries Technical Assistance Service Center MITAC Massachusetts Institute of Technology Activities Committee 50 hits on google down the endless list of this name, I find Mitac PD12TI CC Mini-ITX Motherboard w/ Intel Atom D2500 CPU, Dual LAN, D2500CCE (just wild guess but betting clues and unstated by YOU) ok that is a computer. sure it. a micro iTX PC. with ATOM POS CPU. found their home page next https://mitxpc.com/products/pd12ti-cc-d2550 SO WON"T start means? My guess will not turn ON. what: VGA port dead powered on>? there support page SUX, no manuals at all. runs only windows 7 32bit, and that is now obsolete, I found manual on line, on mirrored sites it uses 24pin 2x12 PSU power supply. power. to turn it on , jumper 2 pins on the header "P" 2x5 pins 6 to 8 jump turns it on. X = KEY 2468X 13579 https://www.cartft.com/support_db/support_files/Mitac_PD12TI_Manual.pdf
6/28/2019 4:28:27 PM • Mitac Computers... • Answered on Jun 28, 2019
Need to verify if my
Probably not too much help right now, but you can get a small device online for just that purpose. Try shopping for "computer power supply tester" Less than $5 including shipping.
2/10/2018 3:53:22 PM • Mitac Computers... • Answered on Feb 10, 2018
0answers
Need BIOS files for MITAC 9515
http://www.biosflash.com/e/Drivers-BIOS-Updates-MITAC.htm
7/22/2015 6:20:50 AM • Mitac Computers... • Answered on Jul 22, 2015
Mitac 9070d case
out with the old in with the new. i think you'll have to get a new one
5/6/2014 10:26:26 AM • Mitac Computers... • Answered on May 06, 2014
0answers
0answers
Mitac GETAC A 320 Notebook Logo
17 questions posted
Top Mitac Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mitac Computers & Internet
Most Popular Question
anyone know grade 8615
  • Computers & Internet
