20 Most Recent Belkin (F5D72304F5D7000) Router Questions & Answers
Just Install the hardware and insert the driver of the router...then follow the instruction...
Belkin... | Answered on Aug 28, 2018
open internet explorer and type 192.168.2.1 and the will get u to the belkin router page and then click on mac address control and then type ur password to get in to the router and it will take u to all the mac address u have allowed or denyed
What is the code that you posted? It is not clear what the issue you are facing is.
Belkin... | Answered on Oct 18, 2013
To reset the Belkin back to the defaultsettings -
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. https://192.168.2.1
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-https://www.fixya.com/support/r3559128-wireless_router_security
Belkin... | Answered on Jun 16, 2012
go to this website
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D7235uk4&aid=7063&scid=282
and download setup cd you will need it to setup the router properly
Belkin... | Answered on Aug 31, 2011
First off, make sure the management IP is indeed 192.168.2.1
to do that start > run > cmd > type "ipconfig" and press enter, the Default Gateway's IP address is the router's IP address.
second step, ping it. you should get a replay back
lastly, if you still cannot open the management page, the issue is probably with your browser, one common reason is a configured proxy server on the browser, remove it.
for Internet Explorer: Tools > Internet options > "connections" tab > press "LAN Settings" > uncheck all three checkboxes there.
I Hope this helps
Belkin... | Answered on Jun 11, 2011
You should be able to download from the Belkin website.
Belkin... | Answered on Apr 18, 2011
Go to this WEB site for instructions on connecting the PSP to a wireless router.
http://fixhomenetwork.com/xbox-play-station-wii.php
Belkin... | Answered on Apr 17, 2011
Access your router's setup page by going to 192.168.2.1. Verify the wireless settings set in your router. Take note of the wireless network name or SSID, the type of wireless security enabled and the security key. Configure these wireless settings in your XBOX
Belkin... | Answered on Feb 23, 2011
Belkin... | Answered on Feb 09, 2011
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Belkin... | Answered on Feb 05, 2011
Hi duke2222171,
For you to access the router page just open a browser then type 192.168.2.1 on the address bar and it will ask you for a username and password.the default username is admin and the password is blank.
Rate me if this works so that i can help others.
Thanks for using Fixya.
Belkin... | Answered on Jan 28, 2011
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Belkin... | Answered on Jan 21, 2011
WIRELESS ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regard ,
Milan
Belkin... | Answered on Jan 11, 2011
Call your internet provider with your account, grab at hand,(if is router from your internet provider)what does appear and what does not appear on your router, maybe its lost it way out.
Belkin... | Answered on Nov 05, 2010
In the case of a lost password you need to push the reset button on the back of the router. Hold it down for 30 seconds and then unplug the router from power. Plug it back in to the power.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "restore to factory default". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Belkin... | Answered on Nov 04, 2010
Belkin (F5D72304F5D7000) Router Logo
108 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
dont remember password
  • Computers & Internet
