20 Most Recent
Tappan TGF320 Gas Kitchen Range Questions & Answers
Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Unlock my Tappan Gas Over Door?
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Rat Nest in oven insulation
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Igniter failure
The igniter is extremely brittle after it has been used. Often times when it fails a small hair line crack can be seen upon physical examination. Although it would appear that contact is still being made, it will not glow and reach the temperature needed for the gas valve to be opened. An Ohms meeter can be used across the two leads after it is removed form circuit I would expect less then 1 ohm on a good one but because even a bad one my be making contact when it is cold as soon as a bad one is energized the gap will open and Ohms will be increased that could not be measured. Just look for a crack, use your finger nail if you feel one it is bad.
Self cleaning oven
After the self cleaning process you might see i wight powdery residue. This can be cleansed out with a damp cloth. No chemicals should be needed. If you use household cleaners you may have some odore when you use your oven so I would just use a damp cloth.
