20 Most Recent Sansui G-5700 Tuner/receiver Questions & Answers
2answers
Sansui G-5700 protection light wont go on
Try checking the speakers and connections. Those symptoms occur if there is a short. Disconnect all spkrs, turn it on and if it stays on connect one speaker at a time until it shuts off.
10/25/2021 10:31:17 PM • Sansui G-5700... • Answered on Oct 25, 2021
There is no sound coming out
I had a very similar problem with my Sansui G5700. Powers on, but no sound. My solution may not fix your problem, but this is what I did to solve mine. Removed the wooden cover. On the main power circuit board ( red circle on attached image) there is a safety relay that activates the speakers. Carefully remove the plastic cover ( should come off easily) spray the contacts with contact cleaner. ( do not use CRC. use a dedicated contact cleaner) Double check all your fuses. Refit the plastic relay cover. Refit the main wood cover. Power on, and hopefully it works :)...Mine has not missed a beat since.( If this didn't work, check if the relay actually switches on and off. The relay may have an open circuit and needs to be repaired/ replaced) 2f650e9f-0e26-4560-8d6b-d075d71217ee.jpg
7/18/2014 5:21:17 AM • Sansui G-5700... • Answered on Jul 18, 2014
Sansui RZ-5100AV Audio Video Receiver. Why does it not have any sound?
Question edited for clarity. It appears to be a known issue and looks like you will need an audio technician. https://www.google.com/search?q=sansui+RZ-5100AV+no+sound ..
2/17/2024 1:03:26 AM • Sansui Audio... • Answered on Feb 17, 2024
I need a 220V AC input to 6V 650mA output transformer for my Sansui Vesta radio, whom can I contact with
Try mouser.com. They have a great variety of electric adapters.
11/24/2023 3:38:03 PM • Sansui Audio... • Answered on Nov 24, 2023
I have Sansui Home theater (HTIB 1003), when. I press on power button, it just turns blue light but it doesn't show Hello words and it does not Load,,,, what can be the problem?
If the TV has no picture or sound, but the led turns from red to blue or green that means the mainboard has sent the power supply board the start up signal. The first thing that needs to be done is the voltages need to be checked to the power board. Follow the steps.
1. Hold the (menu) and (vol-) buttons on the side of the TV.
2. While holding the (menu) and (vol-) button on the side of the TV you also need to press the (power) button on the side of the TV (NOT REMOTE).
3. When the blue light comes on and stays on wait 10 seconds then let go of the (menu) and (vol-) button.
4. Wait 30 more seconds. After waiting another 30 seconds you should see some type of picture appear on your screen. — If those steps do not work then you need to unplug your TV for 10 minutes then hold the (power) button on the side of your TV for 60 seconds - plug in and turn your TV on.
If those steps do not fix your problem I would check to see if your device is still covered under a warranty. If not I recommend www.tvrepairpros.com they will find a technician in your area to further assist you.
11/11/2023 3:23:58 PM • Sansui Audio... • Answered on Nov 11, 2023
Sansui Home Theater HT1B-3000 has no sound. How do I fix it please?
Re-check all of your wires between the TV and the system are fitted correctly at both ends. I usually concentrate on the TV first where I remove ONE connector and wipe it with a DRY lint free cloth and refit it, making sure it is pushed fully in. Then do the same to the next connector, (remove, clean and refit), and so on until they are all done. Then I move to the back of the TV and use the same method. Also do this to any DVD players and anything else you've got plugged into the theatre system. Once you have done this recheck all the settings on the Theartre system AND the TV as sometimes settings can get changed accidentally when changing other settings.
12/16/2022 8:37:26 AM • Sansui Audio... • Answered on Dec 16, 2022
Sansui G5700 powers on, safety light on, am reception and sound good, FM lights up, digital display functions but No sound output..
check speakers and connections if ok possible bad outputs on amp
9/25/2022 7:53:37 AM • Sansui Audio... • Answered on Sep 25, 2022
I need a Manual for sansui speaker system sps1608
as maker on USB/ bluetooth part speakers https://sansuisound.com/
8/20/2022 5:05:26 PM • Sansui Audio... • Answered on Aug 20, 2022
I need to find Sansui SHT-10 service manual or schematic diagram. Please help me.!
This item is not a repairable item. It is a throw away item There is a working one for sale on fleabay for R200. That is about £10 GBP. There are no service manuals or even schematics because when they failed under warranty, they were replaced.
8/11/2022 6:29:28 PM • Sansui Audio... • Answered on Aug 11, 2022
I have a Sansui Artemis sound Bar with wireless subwoofer Iam not getting any sound from subwoofer led light is just red instead of blue when in use how can I go about it to reconnect it.
Hi, Please call 1 618 392 3456 to reach Sansui for help with troubleshooting. They might refer you to the product manual. And if you don't have one, you can email them for the manual and get the page that deals with solving the sound bar sound issue. Thank you
7/27/2022 12:52:12 AM • Sansui Audio... • Answered on Jul 27, 2022
Hello everyone, looking for a long time user manual / operating instructions (not service manual) for the SANSUI RZ-3700av receiver, thanks in advance
google sansui rz 3700av receiver manual try it it is free and easy. there many free manuals for different products on lone free. https://www.manualslib.com/products/Sansui-Rz-3700av-8659147.html
3/11/2022 6:52:35 PM • Sansui Audio... • Answered on Mar 11, 2022
Sansui T-1000 tuner not working.
Question edited for clarity. Does the tuner have an aerial connected to it? Also the Tuner would be better connected to an amplifier, not a pre-amp IMO. Manual and Service Manual https://www.google.com/search?q=Sansui+T-1000+tuner ..
1/20/2022 1:13:01 AM • Sansui Audio... • Answered on Jan 20, 2022
How do you change the stylus on the sansui P-L75 turntable
It uses an SN-707 stylus. The cartridge is not replaceable. It just pulls off in a downward motion.
4/29/2020 6:30:43 AM • Sansui Audio... • Answered on Apr 29, 2020
Sansui G-5700 Tuner/receiver Logo
Popular Tags
4 questions posted
Top Sansui Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Audio Players & Recorders
Most Popular Question
no sound coming out
  • Audio Players & Recorders
