20 Most Recent Linksys StackPro II 100BaseFX Distance Extender (DSHFXSC) Questions & Answers
Turn of router and laptop. Wait minute. Turn both devices on
Linksys StackPro... | Answered on Mar 04, 2018
You can get this driver, and any others, form the Acer site:
http://us.acer.com/
Follow the "notebooks" link.
Linksys StackPro... | Answered on Jun 28, 2010
Do u have a firewall installed? Norton gets thru being a recognized anti-virus, however check your firewall comands & exception and what is allowed.Change this rule or disable Norton/Firewall & try browsing. Also check your DNS & gateway of your ISP.....sodeep
Linksys StackPro... | Answered on Sep 28, 2009
You do have an internet connection, correct?
You must know the make and model and probably the version number of the device in question. You probably can get most of this information theough the Windows device manager. If not, look at the device physically. Google the name/model/version and presto, you will have some guidance. Look for the best match, go to the site, look for download/support and you should be able to get the driver you need.
Alternatively, you could go ditectly to the manufacturer site.
If you dont have an internet connection, I would suggest you get a flash drive and go to your library and use their computer.
I hope this helps.
Linksys StackPro... | Answered on Sep 07, 2009
check the internet connection and try to plug in cable and check if the problems persists..
Linksys StackPro... | Answered on Jul 07, 2009
go to acer and dowmload the drivers youve put xp on a vista machine.but you still require the vista drivers not xp ..and the acer drivers..then your pc will work.i had done the same thing
Linksys StackPro... | Answered on Jun 17, 2009
Hi borzou,
Here is a link that will take you to all the drivers that Acer has for the Aspire 3690.
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%203690.pdf?CFID=481869&CFTOKEN=51293709
Sincerely,
Agent Xiong
Linksys StackPro... | Answered on May 04, 2009
There are several factors that will affect or can cause problems in connecting your Roku to your Router.
If you're getting an error message on Roku like 014, 011, make sure to indicate it in your response. Normally, if you're getting 014 message, you can follow these steps:
. A simple power cycle resolves most of the issues. To perform a power cycle, please follow the instructions below:
1. Unplug the power cables from the modem, router and the Roku player.
2. Connect the power cable to the modem (after a minute). Once all the lights on the modem are lit, plug in
the power cable to the router and then to the Roku player.
3. Go to "Settings" and redo the complete Roku setup.
If the issue continues to occur, please try the channel 1 or 3. Should it persist, you may reset the Roku
player. Here is how:
On the back or bottom of the Roku unit, you should find a recessed little hole.
- Use a pin or paperclip to press and hold the button for 30 seconds (please ensure that the power light
blinks while you are holding it down).
The Roku device will reset to default and be ready for setup again.
If the problem continues, please reflash the software via the secret screen:
1. Press the "Home" button for 5 times.
2. Press the "Forward" button for 3 times.
3. Press the "Rewind" button twice.
4. Choose Update Software and the Roku player will then restart.
You can comment your serial number or the error message that you're getting. If your getting 011, just power cycle your entire network. Also, please make sure that you're not connecting the Roku to a Guest network. The speed of your connection matters as well. It should be atleast 1.5mbps.
Linksys... | Answered 5 hours ago
https://www.linksys.com/ca/support-article?articleNum=140923
Which model?
Go to the Linksys website and download the instructions for your model of extender.
Linksys... | Answered on Dec 02, 2019
The vent actuators are bad. there should be two. one on each side. they are small toy like motors that open and close the vents from within to allow the hot air to blow by closing the vents to the a/c unit.
Linksys... | Answered on Nov 21, 2019
You can get best linksys router support phone number at Toll Free Number ( 1-877-769-0969 ). Linksys router Tech Support number ( 1-877-769-0969 )
Linksys... | Answered on Nov 12, 2019
DO NOT CALL FAKE NUMBERS OR GO TO FAKE WEBSITES
Linksys... | Answered on Nov 11, 2019
this ones for you loser
Linksys... | Answered on Nov 10, 2019
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Linksys... | Answered on Nov 01, 2019
Linksys StackPro II 100BaseFX Distance Extender (DSHFXSC) Logo
13 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
download ethernet controller driver
  • Computers & Internet
