20 Most Recent
Lexmark E332n Laser Printer Questions & Answers
Printer prints off the side of the page
I would be calling Lexmark about this because this is not a user serviceable issue. If you are down to measuring the size of boxes that it prints out and they are not right, I would want to see what the issue is and how to fix it.
E332n lights flashing error
We would need the secondary codes to get the root cause of the problem. Press the Continue button twice to get the secondary code.
Why does the out of toner light still blink?
This blinking Toner light indicates that the Photoconductor kits drum is full and is in need of replacement. Please contact our Technical Support Hotline or one of our Authorized Service Provider (click on this link: http://bit.ly/UeQhSB).
917 error
I am sorry that you are having issues with your Lexmark printer. Please do call out Technical Support Hotline on 1-800-539-6275.
I have a USB Cable
please assure the number of port USB in setting properties with your plugin the your lap top.
if doesn't changed, you can email me....
My Lexmark E332n (b/w laser) has worked perfectly
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
How to reset PC kit
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
I am trying to connect
hi
go to following link you will have your Printer Drivers
http://bstdownload.com/reviews/lexmark-e332n-monochrome-laser-printer-driver/
Paper bail will not make contact with paper
You may have a spring missing which holds this part in place. By having your printer looked at by a certified technician they can see what the problem may be and fix it for you.
Resetting the PhotoConductor Count
Following are the steps that you have to follow:
1. Press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
Thanks
