20 Most Recent
Apex Digital Apex LD4088 40 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 1800:1 Questions & Answers
HOW DO I GET AN ANSWER FROM YOU PEOPLE
by asking the right question. If you ask a vague question you have a good chance of getting a vague answer .
as previously vaguely expained you have to do an auto scan
and let it complete.
This is based on your tv being connected to an antenna and being the model Apex Digital Apex LD4088 40 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 1800:1
You have to press menu button on your remote control when you see the message you saw on the tv screen.about Auto Scan. Then use the left and right arrows to select tv mode. Press the down arrow to select Air/Cable. Press the left or right arrow to select Air if antenna and Cable if it is a cable service. Once you have selected Air or Cable press the down arrow to select auto scan . If air then press right arrow on the remote (if cable then press enter on the remote)
This is explained on page 18 of the tv user manual
http://data.manualslib.com/pdf/1/84/8384-apex_digital/ld4088.pdf?0fa28d37b4d5ca4a9f59538bc95467d9
Tv channel scan
If you are using cable TV the channels could all be scrambled requiring a cable decoder box.
I have a apex digital
WHY would you want to do that? Are the TV speakers better than your Apex?
If your TV audio and video are all passing through the HT first (from elsewhere, like a cable box) you might want to run basic analog audio directly from that source to the TV so you can watch news and such low-fi content without the HT.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
