20 Most Recent
Kyocera FS-720 Laser Printer Questions & Answers
Red light error
Hi Folks, I have just had the same problem with a Kyocera FS-720 that also had the red/orange attention LED staying on permanently after being turned on. Turned out to have an empty toner cartridge. After replacing the toner cartridge, printer is as good as new again.
Cheers
Charlie T
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
I need a Windows 7
here you are
http://driverscollection.com/?H=FS-720&By=Kyocera&SS=Windows%207
Need a driver for printer
Hello, Well i dont have any in mind to tell you, but if you know how to search the net go to google and type in the make of your phone, i believe you will get it.
Does not print. Nothing showing in print queue.
Check to make sure that there is not a paper jam. Also, try rebooting the computer. If this still does not work, uninstall the printer from the computer and try re-installing it using the provided cd or download the drivers from their web site.
