20 Most Recent Kodak 6800 Thermal Photo Printer Questions & Answers
2answers
Mecha error 02 605
kodak 605 mecha error 02 how a problem solving
2/6/2020 6:49:49 AM • Kodak 6800... • Answered on Feb 06, 2020
2answers
Mecha error 03
you need to replace the pinch motor assembly part number:3F4820RH 26142151-p5ooxoyqqeduxgomwqz3vpix-4-0.jpg
4/15/2019 6:44:07 PM • Kodak 6800... • Answered on Apr 15, 2019
KODAK PRINTER 6800 ERROR CODE PAPER JAM 91
3/20/2019 5:10:33 AM • Kodak 6800... • Answered on Mar 20, 2019
3answers
Mecha error 07
Mecha error 07 and 08 are malfunctions of the paper feed pinch motor located in the right side of the paper compartment. The paper feed pinch is the first roller to grab the paper when it feeds into the machine. This error is tricky. I will walk you through a few fixes.
The first fix is to just power cycle the printer and try to reload the paper. Occasionally the pinch arm will end up in the wrong position due to the printer stopping because the ribbon was empty.
The second fix is to check and make sure that the sensor arm is reaching both sensors on the motor. Sometimes the arm binds on the metal plate inside the paper compartment causing it to not reach the sensor.
The third fix is to start replacing parts. The two things to start with would be the sensors and, although rare, the motor itself. After those are ruled out the only other options are the wiring harness running from the sensors to the junction board, the junction board itself, the power cable running from the junction board to the controller board, and then finally the controller board itself.
10/4/2018 9:26:52 AM • Kodak 6800... • Answered on Oct 04, 2018
Service manual kodak printer 6850
how to solve mecha error 03?
8/15/2017 2:13:22 PM • Kodak 6800... • Answered on Aug 15, 2017
Kodak 6800 papper jam 02
replace the paper edge sensor. spider eyes just where the paper feed to the center. part number: 3E6924RH kodak-6800-papper-jam-02-p5ooxoyqqeduxgomwqz3vpix-2-0.jpg
4/6/2016 11:58:36 AM • Kodak 6800... • Answered on Apr 06, 2016
My kodak says incorrect ribbon
new ribbon is not supportive on kodak 6850 so please anybody have a tools to update printer?
12/27/2015 4:12:29 AM • Kodak 6800... • Answered on Dec 27, 2015
3answers
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
11/29/2015 9:38:48 AM • Kodak 6800... • Answered on Nov 29, 2015
It displays system error, paper jam, ribbon empty
Hi Karl, Have you checked to see if the quoted errors are in fact present?
7/23/2015 10:38:49 PM • Kodak 6800... • Answered on Jul 23, 2015
What is main pinch motor
Change this part. Main pinch motor on the left hand side the Centre motor.
6/4/2015 6:29:02 PM • Kodak 6800... • Answered on Jun 04, 2015
2answers
Paper jam 71
Paper jam 71 is an error that occurs when a driver on the controller board (IC-28) begins to wear out, or the timing gets thrown off. This causes one paper feed motor to drag the other one. This error is normally accompanied by a loud grinding noise because of this. Kodak's newest firmware version is supposed to fix the problem. If that has no effect then the fix is to replaced the controller board.
Good luck.
1/20/2015 8:03:01 PM • Kodak 6800... • Answered on Jan 20, 2015
Kodak 6800 Thermal Photo Printer Logo
125 questions posted
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kodak Office Equipment & Supplies
Most Popular Question
mecha error 003
  • Office Equipment & Supplies
