20 Most Recent
LG 60PA6500 60" 1080p Plasma TV - 16:9 - HDTV 1080p - 600 Hz Questions & Answers
What could be causing my LG 60pa6500-ua plasma TV screen to intermittently turn blue and white (video and sound still on and visible) then turn back to normal?
The main power supply regulator section circuit fault.
Va or Vs voltage fluctuating. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
What are the blink codes for an lg 60pa6500 plasma logic control board?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Lg plasma turns on screen lights up no picture
Fault to its main board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
