20 Most Recent Beko 24 in. D3421F Free-standing Dishwasher Questions & Answers
2answers
Upper arm dose not spin
have you checked to see if the arm spins freely if you push it
5/9/2017 11:14:41 AM • Beko 24 in.... • Answered on May 09, 2017
Hi i was wondering if anyone has the same problem
I have never heard of any noise like this in any dishwasher. I suggest you not run it and call a service technician.
4/4/2017 7:21:16 PM • Beko 24 in.... • Answered on Apr 04, 2017
Why does my beko fridge smell inside like stinky
I love cooking
3/29/2015 4:42:31 PM • Beko 24 in.... • Answered on Mar 29, 2015
Have a beko washing machine
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
9/6/2013 10:40:21 AM • Beko 24 in.... • Answered on Sep 06, 2013
2answers
Beko de 3542fs dishwasher
How do you reset dishwasher
6/3/2013 12:39:44 PM • Beko 24 in.... • Answered on Jun 03, 2013
Keeps blowing my electric
You are having a dead short in the dishwasher somewhere. If you would, please do not use it again until it is repaired, as it may burn your house or apartment down. Some one who is good at such things can take it apart and find the short, likely a wire is touching somewhere it shouldn't. Be blessed.
3/16/2013 12:57:26 AM • Beko 24 in.... • Answered on Mar 16, 2013
How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
11/28/2012 12:09:08 PM • Beko 24 in.... • Answered on Nov 28, 2012
2answers
Water is not draining away just a trying noise
CLEAN THE BKO FRM INSIDE
3/25/2012 9:34:29 PM • Beko 24 in.... • Answered on Mar 25, 2012
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
2/21/2012 5:17:12 PM • Beko 24 in.... • Answered on Feb 21, 2012
I have a beko washing machinethe start button
Make sure that the inlet flow is good, remove the inlet valve to check. Also check the door switch and then the connections of the program controller unit. If there is loose connections it can cause errors and halt the program. Also it can be related to the program controller unit if after resetting the above there is no change .
9/30/2011 11:46:00 AM • Beko 24 in.... • Answered on Sep 30, 2011
The water in the dishwasher is not getting hot .
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...Dishwasher SprayArms not SpinningHow to Buy ApplianceParts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The HeatingElement not WorkingDishwasherMaintenanceDishwasherResidue and Film on Dishesheatman101 Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
9/25/2011 4:05:43 PM • Beko 24 in.... • Answered on Sep 25, 2011
The door on my beko dishwasher now just drops open
The spring or nylon cord attached to door hinge has probably snapped. take side off both sides for simple fix. if not then the plastic catch at top of door is probably not engageing correctly. good luck
7/3/2011 10:36:35 AM • Beko 24 in.... • Answered on Jul 03, 2011
My beko de6340s has stoped
Hi
Please take off the lower access panel and clean the drain pump assembly completely, if the issue returns then you'll have to replace the timer/control. Hope this helps...please post back for further assistance.
Daniel
5/29/2011 3:07:55 PM • Beko 24 in.... • Answered on May 29, 2011
The dishwasher is not cleaning properly only cold
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
5/14/2011 11:26:35 PM • Beko 24 in.... • Answered on May 14, 2011
BEKO D3422FS
check that there are no kinks in the drain pipe or that the pipe way is clear.
Thanks J
4/23/2011 7:14:08 PM • Beko 24 in.... • Answered on Apr 23, 2011
Dishwasher is not cleaning properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
2/20/2011 7:43:39 PM • Beko 24 in.... • Answered on Feb 20, 2011
Beko dishwasher not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
11/20/2010 4:14:58 PM • Beko 24 in.... • Answered on Nov 20, 2010
Freezer will not freeze
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
10/13/2010 6:20:31 PM • Beko 24 in.... • Answered on Oct 13, 2010
The dishes are not cleaned properly come out with
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
9/10/2010 12:09:22 PM • Beko 24 in.... • Answered on Sep 10, 2010
Beko 24 in. D3421F Free-standing Dishwasher Logo
135 questions posted
Top Beko Dishwashers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Beko Dishwashers
  • Beko Dishwashers
Most Popular Question
water not draining away just trying
  • Dishwashers
