20 Most Recent Uniden Bearcat BC 145XL 16 Channel Scanner Radio Questions & Answers
This site says they have them but you have to sign up to receive the free download.
platformusers net
Uniden Bearcat... | Answered on Jan 31, 2016
It all depends on the location. Being VHF and not using a repeater or external antenna, the range is likely less than 10 miles. Using a repeater you might get 50 miles or more. If you are thinking long range communications, you really need an HF transceiver. VHF is essentially for local communications.
Uniden Radio... | Answered on Nov 10, 2019
I have Manuals with the update Sheet $14.95 each (706)270 3829
Uniden Radio... | Answered on Sep 17, 2019
If you get clear audio when close to the receiver, it would appear to be a problem in either the antenna or the receiver. Try a different antenna or relocate the antenna. If you adjusted the VSWR low it doesn't mean the power is radiating correctly. Verticals should be on roof, with roof as ground plane. Mounting on mirrors is ok, but doesn't work as well. Also, if you have sheet metal near the antenna, it acts as a ground reflector and can distort or block the waveform. You might also try it with a different receiver, in case yours has a faulty pre-amp stage. It could also be a power amplifier problem in the transmitter, where it shows 5 watts but isn't putting out that amount. You can check it with an RF watt meter.
Uniden Radio... | Answered on Jul 01, 2019
Trying to wire a dm-452 4 pin mic to a 5 pin uniden ... - Fixya
www.fixya.com/.../t22723929-trying_wire_dm_452_4_pin_mic_5_pin
Jan 6, 2014 - trying to wire a dm-452 4 pin mic to a 5 pin uniden washington -Uniden Bearcat Pro PC68XL ... SOURCE: trying wire a superstar dm-452.
How to wire a superstar DM-452 to a five pin uniden and ...
www.fixya.com/.../t26060852-wire_superstar_dm_452_five_pin_uniden
36 mins ago - how to wire a superstar DM-452 to a five pin uniden and washington - Uniden CB Radios question.
Wire superstar dm 452 mic - Answer
www.dqrkc.com/search/...uniden...pro.../wire_superstar_dm_452_mic
... to a 5 pin how to wire a dm-452 superstar 4 pin mic to a 5 pin uniden washingtonit's not possible to wire 4 wire mics to the uniden 5 wire radios without ...
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio ...
Uniden Radio... | Answered on Jun 29, 2019
Uniden Bearcat BC 145XL 16 Channel Scanner Radio Logo
9 questions posted
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
need schematic scanner
  • Radio Communications
