20 Most Recent
Intel D915GVWB Motherboard Questions & Answers
How to incorporate in bois
the usb will ditect as usb removable or usb floppy you can press F8 to change boot order and select flsh drive
Hi, When I switch on
You can install a video card in the AGP expansion slot to replace the faulty on-board video. When you connect the monitor to the new video card it should boot uo with the generic VGA video driver, then you need to install the video driver (CD) that was supplied with the video card, then you can the screen resolution to 1024X768 or higher to suit your tastes.
915 m5 15k92011100
You can find driver downloads for this board at the following location:https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915GVWB
How to reset d915gvwb back to factory setting
Reinstall Windows with the Windows installation CD. You will need the product installation code that is printed on the Windows label that is attached to your computer.Then you need to install the Intel motherboard drivers. You need to download these drivers from a computer that has Internet access then you can copy them to an USB memory stick and install them on your computer. You can download the motherboard device drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
I want intel d915gvwb drivers
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+915+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D915GVWB
I have intel pentium 4
Hi, Try this. ttp://www.intel.com/p/en_US/support/highlights/dsktpboards/d915gvwb
You can download an active x control which will automatacally detect which drivers are missing or are not up-to date.
Can i put a graphics card for my intel D915GVWB mother board?
You can not use PCI-EXPRESS graphics cards. Only AGP 2/4X Graphics Cards Supported ( 1.5V Only) You should look for This kind of Graphics cards.
I recommend , You must try changing your Motherboard with processor and buy a graphics card ( powerful one) to play these games. Otherwise You wont enjoy any of those games you mentioned.
n.b : a common PCI-E card has 16x speed where you cannot use more than 4x on your system.
Mkv files played very slow
you might have too many programs running at the time you are playing your mkv files
scroll to lower toolbar (bottom of screen) right click select task manager select applications also under processes if you see something running that you dont need runing select end now
you might have a virus slowing your computer
you might uninstall some unnecessary programs
and add more ram
hope this will help you
I have no graphics drivers
if your computer came with a motherboard disc the sound
and video drivers could be on it click start control panel administrive tools
computer management device manager scroll to sound,video and game controllers
you might see a yellow question mark? Right click to reinstall drivers
also
Click start control
panel administrive tools computer management device manager scroll to display
adapters + to expand you might see a yellow question mark ? or exclamation mark
! or a red x right click select reinstall drivers or you might need to download one
Click start control panel administrive tools computer
management device manager scroll to display adapters + to expand you might see
a yellow question mark ? or exclamation mark ! or a red x right click select
reinstall drivers also you might
uninstall the display adapter restart your computer then reinstall the display
adapter and its drivers this would apply to the sound video and game
controllers
http://download.cnet.com/%7Bvalue=http://www.download.com/jetway-motherboard-driver/3000-2098_4-163033.html
hope this helps
What happens if the processor
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
