20 Most Recent Intel Motherboard Questions & Answers
What is the question?
Intel... | Answered on Feb 04, 2020
https://www.google.com/search?q=abbreviation+of+elitepvpers
SOLVED: What's the abbreviation of elitepvpers? - Fixya
Jul 18, 2011 - The is no such word, it is made up so therefore there is no abbreviation. For your purpose, it may be 'EpVp'. elitepvpers.com - full of scammers ...
Intel... | Answered on Jan 22, 2020
hii friend how are you listen the hacker is bad of hacker :
Hacking is an act of penetrating computer systems to gain knowledge about the system and how it works.
look this link friend :
http://technet.microsoft.com/fr-fr/magazine/cc160808(en-us).aspx
stop the hacker :
http://techrepublic.com.com/5208-11184-0.html?forumID=39&threadID=192363&messageID=1984821
Intel... | Answered on Jan 07, 2020
Maltesh,
1) IF ALL of the LED (Lights) were on they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Intel D945GCCR motherboard?
Can use up to an Intel Core2 Duo E4700, (800MHz FSB), according to Intel Support,
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gccr
An Intel Core2 Duo E4700 can use up to 65 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
Check the Power Supply.
A Power Supply with a weak voltage power rail, will have plenty of power to light LED's, and maybe spin fans, but Not enough power to turn the Processor on.
No processor, no computer.
The computer isn't generating a video signal.
No Signal to the monitor.
Do you have access to a multimeter, or DC Volt meter?
Test the three Low DC voltages coming out of the Power Supply.
A) 3.3 Volt power rail
B) 5 Volt power rail
C) 12 Volt power rail (ALL are DC voltage)
[ In comparison two D cell flashlight batteries store 3 Volts DC ]
Need guidance with testing post back in a Comment.
Or if you have a KNOWN to be good, and Compatible power supply, that you can borrow for a test, try it.
Regards,
joecoolvette
Intel... | Answered on Sep 29, 2019
With the motherboard in the case and the back of the case away from you the front panel pins are on the front left of the motherboard. They will have simple labels;
PWR power
RST reset
HLED hard dive LED
PLED power LED
You can get it wrong without breaking it so just keep trying until the right buttons and lights work.
Intel... | Answered on Aug 30, 2019
i want to download msi u100x n1996 webcam driver
Intel... | Answered on Aug 21, 2019
The first link are the system requirements for Wolfteam the sec link will be to the reccomended video card granted you can go higher quality above and beyond this but this will play the game well providing that the rest of your system is up to par I currently have the same card and have no isses playing games such as battlefield MOHA NFS games wish the best of luck to you
System requirments: http://wolfteam.komsik.net/SystemRequirements.html
Reccomended VID card:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4680647&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
Intel... | Answered on Jul 09, 2019
Do you have DVD burning software? If not, you can download software that converts and burns the files directly to DVD. Such software is Wondershare WMV to DVD Burner and other titles linked on this page (free trials): http://www.download3000.com/download_47402.html
Intel... | Answered on Jul 05, 2019
Doesnt power off:
I think your front-panel cables arent connected properly. (the picture might be wrong, because not all front-panels are the same)
No video signal:
The problem isn't with your monitor, it's wth your video card, motherboard, CPU or power supply. Do you get the single beep at startup?
Intel... | Answered on Jun 03, 2019
Hi
Yes Nero will do that but you should have full version of NERO to write it as video DVD and select the speed as minimum that will play in your external DVD player
Thanks
Boopathy
Intel... | Answered on May 22, 2019
Hello, I think I found what you are looking for. Just copy and past the link http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=us&lang=en&product=391723&dlc=en& into your browser. This is all the specs and information on you computer. You can download the manual, Drivers and find all your specs.
Copy and past this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00068983&lc=en&dlc=en&cc=us&lang=en&product=391723 for all the information on your motherboard.
If this is not your exact motherboard I think this will put you on the right track to find it. I hope this information helps and you have a great weekend
Intel... | Answered on Mar 18, 2019
  1. You might try using a different power or SATA cable to the drive. One of them may be defective.
  2. If your BIOS cannot see it then Vista cannot see it.
    Check your BIOS settings....you might need to enable SATA in your BIOS
I hope this information will be helpful. Thank you for using FixYa!
Intel... | Answered on Mar 10, 2019
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
Intel... | Answered on Mar 09, 2019
i need intel 945GCp board driver cd...........
Intel... | Answered on Mar 08, 2019
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer CRYSTAL_XP
Generator crystal
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2010-03-04
Time 09:01
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message P4M80-M4 (4M80M609 BF)
System BIOS Date 06/09/07
Video BIOS Date 08/15/06
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
it is a p3 m/b. 1 gb is not support
Intel... | Answered on Dec 25, 2018
my system mother board is MSI N1996. After formating my system mu audio and vidio drivers ane not working. I dont have any CD also. Can you slove the problem.
Intel... | Answered on Nov 18, 2018
Intel Motherboard Logo
5,393 questions posted
Top Intel Computers & Internet Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
motherboard driver link in gigabyte
  • Computers & Internet
