20 Most Recent
Intel D845GLLY Motherboard Questions & Answers
3 beeps after interval
Usually and indication of a memory issue. Power off the computer and pull all memory out. Place memory in one at a time into a slot and power on. If it fails on a particular chip, that would be the bad memory module. If it fails on every chip, the slot could be bad. If it does not fail and any chip, try each slot individually. It should fail on one slot and that would be a bad slot on the board.Hope this was helpful
.i want to change my
make sure ram module its securely seated also this ram might not be compatable with your computer try to keep the same type of ram you already have is it ddr2 or ddr3, sdim,sim 30 pin,sim 72pin ,or dimm
hope this helps
I'm unable to recover the
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS
BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps also
http://majorgeeks.com/downloads25.html
here you will find a vast array of bios tools
I want free download for
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%C2%AE+845+Chipset+Family&ProdId=757&LineId=127&FamilyId=40
Download the required driver from this URL, ITS free
Beep after every 10-15 seconds,
Depending on the beeps, it can mean different things.
The most common error is because your RAM sticks are loose. If you are proficient in operating PC hardware, open your case, remove the RAM sticks, brush the contacts slightly for dust, and put them back in, lodging them properly.
If you aren't sure of what to do, ask someone whose down this before. You dont want to pull out the wrong components.
MY MOTHER BOARD NMBER
Are you sure you downloaded it for your operating system? Try running the program as administrator. Try playing with the compatability options also
My motherboard is that of
Do the following:
- Control Panel
- System
- Hardware
- Device Manager
- Look for hardware listed under unknown, your system most likely tried to load the audio driver and couldn't find it at the initial software install of XP
- Uninstall , Reboot your system, your system will try and reload the driver...point it to the correct file location or install manually
I am unable to find
Try using the FREE Intel Driver Update Utility from Intel, a "trusted" source.
From Intel:
"The IntelĀ® Driver Update Utility keeps your system up-to-date. It
detects which driver updates are relevant to your computer, and then
helps you install them quickly and easily."
http://www.intel.com/support/detect.htm
Here's a direct link to your motherboards support section at Intel dot com
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845glly?wapkw=%28Intel+Desktop+Board+D845GLLY%29
Oh, and don't forget to back your drivers once everything is running crisp and clean again. I use "Driver Max". It's also free and easy to use. Good luck friend!
