20 Most Recent
Sigma EF-500 DG for TTL Flash Questions & Answers
Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
Can I use a sigma flash EF 500 with Sony Alpha 350
Yes, if it has a Minolta/Sony mount. The Sigma EF 500 has been producedin different mount, so that the model can fit different cameras from different producers. A Sigma flash for Sony should have SO-ADI written on it.
I can not get the
Clean as much corrosion as you can from the contacts. If you've already done so then the corrosion has spread to the wires connected to them and will need to be replaced. This means opening up the unit and unsoldering the old wires between the contacts and the circuit board and replacing them with new ones.
You'll need to take great care as a flash capacitor can store a lethal charge, and you'll also need good soldering skills to both ensure that the new joints are sound and that you don't put too much heat into the circuit board causing damage.
The actual repair though just costs a couple of pieces of wire and a bit of solder, so is very cost effective if you have the tools and skills.
Sigma ef-530dg st pa-pttl is stuck wont auto zoom
IS the flash being used on a compatible model camera? If I understand the numbers that is for a Pentax camera and is incompatible with other brands of cameras.
Double check the flash to see which cameras it is dedicated to and check to see that the flash contacts are clean on the cmaera and flash. Otherwse it will need to be sent to Sigma for repair.
My cell sigmatel s9 china made not getting connect with computer and as well as internet
usb is not getting as u may not have installed ur usb driver.....i m
having same sigmatel s9 and it connects fine.....t v mei sirf dd he
aaega can't help..., it supports .nes roms , search for such
file games on google and store it in MyNes folder , they will run under
fc games..........i have more than 30 such games they work ausome
...these are those games which u used to play on tv video games.. for
more help call me 09968736808
Connectavity
Nokia PC suite will not work for sigmatel..
Sigmatel will work as a plug and play device like your pendrive
When you insert the data cable in the computers USB port the Phone would get a screen asking you to choose from 3 option
select the first option mass storage and then use you phone as a pendrive to move music files, videos and even snapshots....
i hope this helped otherwise pls post on any problem you face during these steps
EF 500 Sigma flash
I found the solution by doing the following, all solved:
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I used dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
1. Sigma EF-500 DG ST 2. Quantaray 7500A
A: For Sigma issue:
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I use dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
Sigma EF-500 DG super
Sigma Flash EF-500 DG SUPER
I use one of my cams with a sigma 500 DG-ST in a nightclub
ive done 3 of the hot shoe connectors in the last year
look up sigma's website and find the contact info
give them a call and they should after some arguing ship you out the parts
every time i have ordered parts they try and get me to send it in for repair even though by the time i am ordering the parts the flashgun is already in bits & i tell them this they keep telling me how dificult it is to do...
for the canon fittment do the following
at the base of the flash remove the 4 screws
this removes the bottom section
unclip the wireing harness
there are 2 screws securing a small metal plate remove them
now there are 4 screws securing the small PCB, remove them, you can now take out the boot from the bottom be careful as the pins and the springs will want to come out
pay atention to the locking pin and how its orientated
swap over the broken boot with the replacement then retrace your steps to get it back together
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
