20 Most Recent
Sony KDL22BX300 BRAVIA BX300 22 Class LCD HDTV - 720p, 1366x768, 16:9, Questions & Answers
How to Repair power suplay
Have a service manual smd tools a scope a good observation and have much pati?nt , clean print good before if you remove parts and also if parts replaced bulged capacitors or shorted primary shortened parts fuse resistors controlled ? bridgediode makes dc ? primary hot all ok ? secundairy control the more heavy parts like coils on the print for bad solderings and active components most types are mounted on a heatsink look by litte careful move manipulate and look inbetween on botton site for bad (loose) solderings it is not only to look because its hard to see for most people that also the heavy parts may have problems, fuse resistors in the secundary powerlines that goes to tuner i2c sda slc clock and many more things but be pati?nt sometimes it can be something you never have tought it was because of Not visible conductive pollution , thats why i here make a warning with not high priority, because if smd devices are used in power supply or else parts , i ask everytime by people who have for a short time ago have the walls indoors has papered because of the conductive properties of methylcellulose (wallpaperpaste) and static conductive sensitivity and disturbances in the interior touch of wallpaper paste the cellulose fabric pulls everywhere and many times I have seen this over the years also by hi-fi equipment and especially the Internet modems that's why it often precedes cleanse research is so important. if you decide to make wallpaper do make the paste outside the house .
Sony bx300 shakes picture vaticaly but sound is ok
Does it do it on all sources? I wonder if you should start by checking that then reseating all cables like scart leads. If its the same on all sources.
Make sure it's set to the correct standard.
Is the firmware up to date? (firmware depends on where you are)
can you report back with more details?
LCD Goes In Standby Mode & Red Led Blinks Two Times
Over-Current Protection (OCP). Simple as circuitry shortage to power supply. You would need to have this serviced by a trained technician. This is not something that you want to try to service on your own. Consider your opportunity cost when servicing this item. If it costs you half of what you paid, you might as well purchase a new monitor.
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
Sony cfd-s70 Will Not Read CDs
There are a few possible causes for a Sony CFD-S70 CD player not reading CDs. Some possible issues include:
- Dirty or damaged CD: Make sure the CD is clean and free of scratches or damage.
- Dirty lens: The lens that reads the CD may be dirty or dusty. A cleaning disc can be used to clean the lens, or you can use a soft, dry cloth to gently wipe it clean.
- Faulty lens: If the lens is faulty, it may need to be replaced.
- Faulty CD mechanism: If the CD mechanism is not working properly, it may need to be repaired or replaced.
- Power Supply Problem: Make sure the power supply is connected and the power outlet is working.
- Firmware issue: A firmware issue could prevent the CD player from reading CDs. You should check the Sony website to see if there are any firmware updates available for your specific model.
If the problem persists after trying these suggestions, it is recommended to take the device to a professional repair service or the nearest Sony Service center.
Sony TRV 740 E Fehlercode C:31:40
Der Fehlercode C:31:40 bei Sony Camcordern deutet auf ein Problem mit dem Motor des Kassettenfachs hin. Es kann sein, dass der Motor blockiert ist oder dass es ein Problem mit den Sensoren gibt, die den Status des Kassettenfachs ?berwachen. Um das Problem zu beheben, k?nnen Sie folgende Schritte ausprobieren:
- Entfernen Sie die Batterie und das Netzkabel des Camcorders und lassen Sie das Ger?t f?r einige Minuten ausgeschaltet.
- ?berpr?fen Sie das Kassettenfach auf lose Teile oder Fremdk?rper, die m?glicherweise blockieren k?nnten.
- Versuchen Sie, das Kassettenfach vorsichtig zu schlie?en und zu ?ffnen, um zu sehen, ob dies das Problem l?st.
- Wenn das Problem weiterhin besteht, k?nnen Sie versuchen, das Kassettenfach mit Druckluft zu reinigen, um m?gliche Blockaden zu entfernen.
- Wenn alle diese Schritte fehlschlagen, kann es ein mechanisches oder elektronisches Problem sein, das eine Reparatur durch einen qualifizierten Techniker erfordert.
Es ist auch m?glich, dass das Problem durch eine defekte Cassette verursacht wird. Wenn m?glich, versuchen Sie, eine andere Cassette auszuprobieren, um zu sehen, ob dies das Problem l?st. Wenn das Problem weiterhin besteht, liegt es h?chstwahrscheinlich am Camcorder selbst.
Sony Playstation 3. Infamous intro doesn't load
- Restart the console: Sometimes, restarting the console can resolve software issues and help the game load properly.
- Check for updates: Make sure you have the latest firmware installed on your PlayStation 3, which can be done by navigating to the "Settings" menu and then to "System Update".
- Check the game disc: Make sure the disc is clean and free of scratches or damage. If the disc is damaged, it may need to be replaced.
- Reinstall the game: Try uninstalling the game and reinstalling it from the disc. This can help resolve any corrupt data that may be causing the issue.
- Try a different game: If the issue persists, try playing a different game to see if it's specific to Infamous 2 or if it's a general issue with the console.
