20 Most Recent Intuit QuickBooks: Pro 2005 for PC Questions & Answers
How to fix it
Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are restoring your company file
You are creating a back up
http://support.quickbooks.intuit.com/support/articles/SLN40226
for more help visit
QuickBooks Technical Support
Intuit... | Answered on Sep 11, 2019
I don't know what type of error you face while installation of QuickBooks but i share some of Intuit common error so choose the right one for you Links for installation errors . if still not able to get and need any technical help follow Intuit Tech Support .
Intuit... | Answered on Sep 06, 2019
You can find the repair feature in the control panel add/remove programs window.
Open your control panel, click on add/remove programs, scroll down to QuickBooks and click remove (it won't you will be prompted to either repair or remove). Have you disk handy in case it prompts you for it.
Intuit... | Answered on Sep 05, 2019
here is a goos search with multiple videos with tutorials galore at your fingertips. pick and choose whichever video that matches your taste and learning style.
Google
Intuit... | Answered on Jul 03, 2019
If you are trying to reconcile to your bank balance, you should not be reviewing the "deposit detail" report.
1) Go to "Banking" then "Reconcile"
2) If the "Opening Balance" is incorrect, then close the "reconcile" window and go to "Reports" then "Banking" then "Bank Reconciliation Discrepancy" report. (This report will reveal what changed after your last successful reconciliation).
3) If the "Opening Balance" is correct, then you want to press "continue" to focus on the bottom of the window, which reveals "total deposits marked as cleared". If you have duplicates, you will see them on the right side of the screen, but the ultimate goal is to have a "Deposits Total" (in QuickBooks) that agrees with the "Deposits Total" (per Bank Statement).
The "Deposit Detail" report is a "Journal Report" to show you details of historical deposit records, Has nothing to do with "reconciling" your current bank balance.
Intuit... | Answered on Jun 08, 2019
Tip
Quickbooks Download Websites
IF you are using Intuit Quickbooks, Here's the download Websites:
Quickbooks Pro 2008 : Download
Quickbooks Premier 2008 : Download
Quickbooks Pro 2009 : Download
Quickbooks Premier 2009 : Download
Quickbooks Pro 2010 : Download
Quickbooks Premier 2010 : Download
Quickbooks Pro 2011 : Download
Quickbooks Premier 2011 : Download
Please make sure you know your License Numbers
Please rate if this helps..
Thanks!
on Jun 06, 2019 | Intuit QuickBooks: Pro 2005 for PC
Sounds like hard drive errors due to possible hard drive failure.
Intuit... | Answered on Mar 18, 2019
Explore the QuickBooks 2005 CD, go into the QuickBooks folder and double click quickbooks.msi - this will install QuickBooks without checking for the old/outdated Flash Player 7.
Intuit... | Answered on Nov 26, 2018
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Step one is run scandisk. If you have a cross linked or corrupted file it will sort that out automactically. Step 2 is to google "where is the quickbooks repair feature".....odds are someone has used it before. Step 3.....save your Quickbooks database (in at least two places) and delete and reinstall Quickbooks if all else fails.
Intuit... | Answered on Sep 06, 2017
Best thing is contact with the seller
Intuit... | Answered on Jul 17, 2017
Usually a license number, product code error. Often seen on pirated software, but can also come from a damaged install.
Be careful, trying to reinstall an older version like this can result in the product going back to an old release, and the update files are no longer available.
Intuit... | Answered on Jan 06, 2017
This usually means the license number and the product code do not match the product. Often seen in cracked/pirated software.
You probably opened an old file. You will need to find the current file that you were using. Use the search and search for all files ending in .QBW
Check the dates they were last used (you don't want the one with the most current date since that was the old file that was opened.)
Intuit... | Answered on Jul 16, 2016
Correct. That version was made well before Win xp. It does not understand the folder arrangements for Win 7 or 8. You would need a newer version.
Intuit... | Answered on Mar 10, 2016
the short answer is YES but you have to get it from the makers of Quickbooks themselves.
https://gethuman.com/phone-number/QuickBooks
800-488-7330
QuickBooks Customer Service
First call 800-488-7330; Follow prompts
In general, help is available at this phone number for:customer problems support customer care issues questions billing sales customer service
Intuit... | Answered on Jul 28, 2015
Create an invoice to anyone for anything for 1.00. remove the To Be Printed check.
Save it.
Then delete the invoice.
To be printed is a sticky setting that is held based on the last transaction..
Intuit... | Answered on Dec 23, 2014
QB 2005 does not run in Win7.
Intuit... | Answered on Nov 25, 2014
Only Intuit would have record of this.
Intuit QuickBooks: Pro 2005 for PC Logo
202 questions posted
Top Intuit Computers & Internet Experts
NET MAN
Level 1 Expert
Ekse
Dalynn Turner
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intuit Computers & Internet
Most Popular Question
quickbooks 2005 error 1603
  • Computers & Internet
