20 Most Recent 2wire HomePortal 100W (1000-400026-000) Wireless Router Questions & Answers
2answers
I can'T setup internet on laptop
1st step is to call netzero and as per the setup get it configured.
2nd on your comp go to control panel-network connections- delete all the connections listed their- insert the disc provided with router- run the setup and install it- then connect the usb of router and see if it works..
Clarify ur setup more for more help
12/4/2017 12:27:08 PM • 2wire HomePortal... • Answered on Dec 04, 2017
I forgot dax network switc password can i breakmy
i forger my dax router password , how does it break.
11/25/2016 5:02:53 AM • 2wire HomePortal... • Answered on Nov 25, 2016
I forgot the password for
With the two wire home portals, you will have to contact your service provider for dsl/fiber to give you the password, you generally will need to provide them with a few different forms of ID, such as your account number, last four of your social security etc...
8/20/2016 10:58:43 AM • 2wire HomePortal... • Answered on Aug 20, 2016
2wire modem reset
Reset can mean to simply turn off power and then turn it back on.
8/4/2014 4:40:46 AM • 2wire HomePortal... • Answered on Aug 04, 2014
0answers
Forgot password on modem
There a couple of things you can do, 1. Reset the Wireless Device to Default Settings and reconfigure the SSID and Security, (note to self: tatto password on body) OR , use this little program, while connected to the wireless device via a ethernet cable or another computer already connected to home wireless: http://www.softpedia.com/get/Security/Decrypting-Decoding/WirelessKeyView.shtml . The program is safe, your Anti Virus my ID it, but allow to run, I use it often.
12/17/2012 11:30:48 AM • 2wire HomePortal... • Answered on Dec 17, 2012
2wire drivers 3800hgv-b
Hello here is the homepage:http://support.2wire.com/index.php?page=view&article=768If i am wrong by the product seach here:http://support.2wire.com/index.php?page=download&cat=1Good luck
11/21/2012 4:56:27 PM • 2wire HomePortal... • Answered on Nov 21, 2012
2answers
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
7/4/2012 2:18:12 AM • 2wire HomePortal... • Answered on Jul 04, 2012
Default router password is not working.
Are you sure you reset it ? Try holding the reset switch with power off and unplugged for a few seconds, then try resetting with power on.
  • If you do not remember your password, you can click "I Forgot My Password" on the login screen and the 2Wire will provide you with a password hint.
  • If you still do not remember, you can click on "I Still Don't Remember My Password" and the 2Wire will prompt you for the system key.
  • The system key is located on the side of the 2Wire HomePortal on a sticker and is a 10-digit number surrounded by brackets (ex: [1234567890]). It is located between the two barcodes on the sticker (see image below).
  • Once you enter the system key, the 2Wire will allow you to reset the password to anything you like.
If after your hint is shown to you, you still can't remember your password, there is a "I still can't remember my password" link that you can click to take you to a page to obtain a temporary password. To obtain a temporary password, you must call the support telephone number on the screen and provide the special code number that is generated by your HomePortal. The support representative will use this special code number to generate a temporary password. Once you have entered the temporary password, you can then change your password and enter an appropriate hint.
6/20/2012 3:30:07 AM • 2wire HomePortal... • Answered on Jun 20, 2012
I am having dax 5026MGV switch tel me the how to configure
Step 1:Connect the Switch using the console cable given in XP MachineStep2:Start-programs accessories->>Accessories-->>>Hyperterminal- a new window will openStep 3:type en ->enable command config t->configuration ip address (type ip here)ex:172.20.0.3 ( type subnet mask)255.255.0.0 wr->save commandThis is the initial step for ip configuration for the switch..
10/2/2011 4:04:08 PM • 2wire HomePortal... • Answered on Oct 02, 2011
2answers
Where to find password to
Hope this helps
Chris (ziraffa)
9/27/2011 2:56:29 AM • 2wire HomePortal... • Answered on Sep 27, 2011
How to Reset Password of
Hello. Try opening your internet browser and on the adress link type 192.168.1.1 that will take you to your rooter's configuration page. It will propably ask you for a pass there to login. I hope you remember that ( i think the default username/pass is admin/admin) once you are in search the page for "wireless settings" and you will be able to put your new pass there. cheers
5/4/2011 11:19:24 AM • 2wire HomePortal... • Answered on May 04, 2011
2answers
2wire 3800HGB-B interference
I would increase the wireless power inside the modem. This will boost the signal allowing it to stay connected more often.
- open IE
- browse to gateway.2wire.net
- homenetwork icon
- wireless settings
- enter your system password
- If your on channel 1 or 11 the power will only be able to go to 4.
- Change to a wireless channel between 2 and 10
- Increase the power to 10
- Save
4/8/2011 3:59:04 PM • 2wire HomePortal... • Answered on Apr 08, 2011
Att replaced the modem the
do you have the included CD with this? It has a step by step guide to setup the wireless.
3/1/2011 4:01:38 AM • 2wire HomePortal... • Answered on Mar 01, 2011
2wire HomePortal 100W (1000-400026-000) Wireless Router Logo
59 questions posted
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • 2wire Computers & Internet
Most Popular Question
am having dax 5026mgv switch tel me
  • Computers & Internet
