20 Most Recent Samsung Galaxy Tab 2 7.0 Questions & Answers
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
Samsung Galaxy... | Answered on Jan 12, 2019
Sound like a corrupt load.
Try to re-flash or upload a current version
The Galaxy is a current model and may be under warranty
Samsung Galaxy... | Answered on Dec 19, 2018
Tip
How to force Samsung Galaxy Tab to shutdown
1.There is no "force shutdown" as far as I know, but you can force a reboot by holding down the power button for about 15 seconds.
2.No force shutdown for galaxy tab, but you can use this trick.
  1. Plug the charger into your galaxy tab.
  2. Hold down power button for 10 seconds, and wait to reboot.
  3. After that, the screen will be change with charging battery.
  4. Plug off your tab, and it will be shutdown.
  5. For Tab S and Tab A
    Should work with 8.4 or 10.5
    6.Hold the Power button, Volume Down button, and Menu key for 10 seconds. You will enter download mode, simply press the volume down button to restart tablet.
    After reboot, you tablet should perform as normal
on Dec 17, 2017 | Samsung Galaxy Tab 2 7.0
found this for you:
https://productforums.google.com/forum/#!topic/play/xPUdySfE3IY
Samsung Galaxy... | Answered on Aug 16, 2016
tablet won't charge
Samsung Galaxy... | Answered on Jul 01, 2016
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Samsung Galaxy... | Answered on May 29, 2016
Could be a bad cable, bad power supply or bad the micro usb port? Just a thought.
Samsung Galaxy... | Answered on Apr 18, 2016
The option to keep the display bright is not found under settings in the Android app, but under the font settings. If you tap the centre of your screen whilst reading your book the icons will appear at the top of your screen. Click the font size icon, and a drop down list of settings will appear. The one at the bottom deals with brightness.
Samsung Galaxy... | Answered on Mar 14, 2016
Some talk back modes will not allow passwords. It is a security thing. I'm not sure about yours, but that is probably the issue.
Samsung Galaxy... | Answered on Feb 15, 2016
How to set up and use email on an Android tablet - PC Advisor
www.pcadvisor.co.uk/.../how-to-set-up-and-use-email-on-an-android-tab...
Apr 18, 2011 - Setting up an email account on your Android tablet is not a tricky task, and on our Samsung Galaxy Tab it is extremely straightforward. But you ...
New emails not showing up in Gmail app - Android - Stack ...
android.stackexchange.com/.../new-emails-not-showing-up-in-gmail-app
Aug 2, 2013 - I have 2 different Android devices: a Samsung Galaxy Reverb ... I have to manually change from Priority Inbox to Normal Inbox (or vice versa) in order for the new emails to show up in my list. ... Why does the new Gmail address not show on the Samsung tab 2 version 7.0? ... Turn PS3 Slim into Linux server.
How to Set Up E-mail on the Samsung Galaxy Tab - For ...
Samsung Galaxy... | Answered on Jan 17, 2016
Maybe you should stop sending them from your tablet to your phone.
Do you have some text forwarding feature activated?
Samsung Galaxy... | Answered on Dec 31, 2015
Browse the setup parameters, you should find the answer there (or in the manual...).
Samsung Galaxy... | Answered on Dec 22, 2015
edit your profile to change or call cust service for samsung:
1 (800) 726-7864
Samsung Galaxy... | Answered on Dec 05, 2015
Samsung Galaxy Tab 2 7.0 Logo
Popular Tags
338 questions posted
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Tablets & eReaders
Most Popular Question
tablet charge
  • Tablets & eReaders
