20 Most Recent Quantaray 28-90mm F3.5-5.6 Autofocus Zoom Lens for Minolta Questions & Answers
0answers
I'm looking for a replacement mount for a Quantaray 28-90mm; for Nikon
Contact Sigma, That's who made the lens for Quantaray,
1/16/2015 9:14:59 PM • Quantaray... • Answered on Jan 16, 2015
I have a Quantaray 28-200mm AF zoom lens Nikon, I use Nikon D80, are they compatible?
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
7/15/2014 3:17:40 AM • Quantaray... • Answered on Jul 15, 2014
0answers
I have a Quantary zoom lens 28-90mm
Fitting is not always the solution. It is the software which recognises the hardware attachements. Either upgrade your camera software or use only the manufacturer recommended add ons. [email protected]
3/26/2010 9:59:23 PM • Quantaray... • Answered on Mar 26, 2010
I purchased a Quantaray Autofocus Lens/Manualfocus
Hard to say without more info.
Is the lens just bought new? If not, it likely is 'chipped' for the Canon AF film cameras. I do not recall if Quantaray rechips their lenses. I believe Sigma does theirs, but not sure about Q~. If you got the paperwork with the lens, contact a repair center or Quantaray.
Contact US1 Photo at 877-300-8070. they are a Quantaray dealer. Ask for the number to the distributor, warranty repair facility and for the number of the quantaray home office. One of them should help you get the right lens.
lightspiritphotography.com
1/3/2010 3:55:43 AM • Quantaray... • Answered on Jan 03, 2010
I have a Quantaray 28-200 mm f/3.8-5.6 AF Zoom
The Nikon D40 requires the use of AF-S/AF-I lenses. Here is a chart of lens compatibility for Nikon SLRs:
Nikonian.org
12/15/2009 1:43:03 PM • Quantaray... • Answered on Dec 15, 2009
Broken locking ring on Quantaray 28-90mm. 1:3.5-5.6
Hey Quiltzlady,
If you were an authorized service technician you could probably order this part from the manufacturer, and if this camera is really only $90 to purchase new it is very likely the cost of the repair would not be worth doing. The suggestion to super glue the ring back together might work but I would try epoxy being that it is a lot stronger, but remember you run the risk of rendering the lens inoperable when you involve glue with something that relies on moving parts to operate properly. Another suggestion is to find the same lens, but broken, for sale that this ring is not broken on, and use that lens as a parts lens I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
5/23/2008 4:43:42 PM • Quantaray... • Answered on May 23, 2008
Quantaray 28-90 mm f/3.5-5.6 af macro telephoto lens for canon
That info can be found right here on Fixya
2/9/2008 11:28:26 PM • Quantaray... • Answered on Feb 09, 2008
I have a Quantaray 100 ` 300 mm zoom bought at Ritz.
Return to vendor for repair or replacement
6/11/2017 12:09:40 AM • Quantaray... • Answered on Jun 11, 2017
The focusing ring is hard to turn on my 28-200 quantaray lense for my nikon camera
Time for a CLA. The focus mechanism will is usually filled with grease, makes it smooth turning, if that grease separates it can make things difficult. Also, it could be something is misaligned with the helicoid. Here is a YouTube video that will explain how they work: https://www.youtube.com/watch?v=n_Lji91nIos
3/2/2016 6:39:56 PM • Quantaray... • Answered on Mar 02, 2016
Need manual for quantaray PZ-1 DSZ flash
You need to contact local dealer , Or if you have the Box, contact who made it. Or see if Manual can be downloaded from Product Web Site
1/6/2016 8:25:10 PM • Quantaray... • Answered on Jan 06, 2016
Quantaray tech-10 75-300mm NF AF F4-5.6 for Nikon. How do I unstick zoom?
Hi Nicolas. Normally, this problem comes from a loose screw and roller that makes the mechanism gets stucked.
11/10/2015 3:33:24 PM • Quantaray... • Answered on Nov 10, 2015
How can I get my cracked Quantaray lens repaired
Sorry, you have not said where your country of origin nor which lens needs repair, thus we cannot make any suggestions. There are numerous repair shops around the world. Doing a Google/Bing/Yahoo search will provide you repair shops; one may be close to you. Also, depending on the lens you may be better of replacing it with a more updated better quality one; just a thought.
7/2/2015 5:56:30 PM • Quantaray... • Answered on Jul 02, 2015
Hello, I own a Quantaray 28-90 MM zoom Macro lens. I would like to know its equivalent Nikon lens, which would be one of the following: 1) D or G type Nikkor 2) CPU Nikkor lens other th
I'm not sure why you want to know this. It is a lens fitted for a Pentax camera. Nikon does not make a 20-90 mm Macro lens. Then it has a aperture from 3,5 to 5,6. It never would work on a Nikon, unless you have an adapter and then it still only could be used in manual mode. You have to do all settings, manual. not only the focus, but also the aperture, shutter time and ISO settings. I use a Nikor 24-85 mm f 1:2,8-4 D Macro, 1:2. With this lens when in focus the object is only half the size of the original. I think it comes close to the 28-90, but it is at least 5 times as expensive. When you are really in for macro photography, you better choose a prime macro, like the 40 or 60 mm from Nikon. both are 2,8 and not as expensive as the zoom version. The results will be much sharper. When you are talking of equivalent, I don't know what part should be equivalent, because that is important to know. As long as the focal length is the same and the aperture, you can make the same perspective pictures on the same distance. Only when you buy a DX, or even e lans for a four thirds camera, still the focal length will be the same, but as soon as you put these lenses on a camera with a larger sensor you will get massive vignetting. A lens made for a full frame (35mm) camera, when used on a DX or four thirds camera, will give the same perspective and will give no vignetting on a camera with a smaller sensor.
2/1/2015 7:31:52 PM • Quantaray... • Answered on Feb 01, 2015
Quantaray 28-90mm F3.5-5.6 Autofocus Zoom Lens for Minolta Logo
18 questions posted
Top Quantaray Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
View Most Popular
Quantaray Cameras
  • Quantaray Cameras
Most Popular Question
purchased quantaray autofocus lens
  • Cameras
