20 Most Recent
Quantaray 100-300mm F4.5-6.7 Zoom Lens for Canon AF Questions & Answers
I use this lense with a Canon rebel and get an
Wow, I'm surprised to actually tells you to clean the contacts? What model Canon Rebel do you have? Okay for cleaning the contacts simplest and most effective way is with a good clean new red rubber pencil eraser. Make sure the camera is off and remove the lens, place the camera body face down on a clean lint free surface or install a body cap if you have one. Hold the lens as vertical as possible but tilted slightly to be able to see and work with the gold contacts. Lightly rub the contact surface with the eraser, it won't look as if you have done much but it does shine them up well. When you have finished cleaning them use a lens cloth (not a tissue) to lightly clean any rubber dust from around the contacts and the rest of the mount. There shouldn't be much if any you are polishing the surface not erasing. Set the lens aside and while holding the camera as much as possible lens side down take the eraser and gently clean the contacts again it doesn't take much don't forget you are polishing not erasing, a few passes should be all it takes. Once done again use the lens cloth not a tissue and clean the area of any dust that may have occurred. Assemble the lens and camera and turn it on.
On another note but a related subject. How new is your Rebel compared to the Quantaray lens? If the lens is newer then the camera that's fine but if the camera is newer then the lens this also may be part of the problem.
1/19/2011 6:08:52 PM •
Quantaray...
Answered
on Jan 19, 2011
I have a 200mm lens
Check that the contacts on the lens are bright and clean. If they are then you have a faulty lens which must be sent away for repair.
If it's under warranty then it will be free, if not then there may be a fixed price repair policy and you'll need to compare the fee charged to the cost of a new or used replacement lens.
9/11/2010 11:37:45 PM •
Quantaray...
Answered
on Sep 11, 2010
Good morning. I have an
The older lenses will work with the Canon digital cameras, but they will be manual focus and you will need an adapter. The adapters are available at camera shops like B&H. I use some older lenses for macro.
8/16/2010 12:06:05 AM •
Quantaray...
Answered
on Aug 16, 2010
POSSIBLE MOLD INSIDE CAMERA LENS
It is lens fungus and you're correct in your assumption that it's uneconomical to professionally repair on your lenses. But it need to be pretty bad before it affects image quality so don't junk them just yet.
Some types of lens fungus can be killed simply by leaving the lens out in sunlight, but I'd suggest that it's better to leave them exposed to the indirect sunlight on a bright overcast day to prevent any chance of sharply focussed light burning the inside of the lens. Killing the fungus won't remove the dead stuff but it prevents the problem getting worse.
5/29/2010 9:19:58 PM •
Quantaray...
Answered
on May 29, 2010
What is this lense best suited for
Like all Quantaray lenses, this lens is a very cheaply built model and so lacks the refinements, build quality and optical capabilities of better lenses. As a result, it does not have a macro mode so is not designed to focus on nearby objects.
That just leaves it as a 100-300mm telephoto zoom lens. The 100mm end may be suited to head and shoulder portrait shots (if it can focus close enough), the 300mm end is a long telephoto for subjects such as architectural close-ups and best used on a tripod or monopod to avoid unsharpness caused by camera shake. Usually a 300mm would be suited to wildlife shots, but the very slow f6.7 maximum aperture at this end really limits this function to non-moving objects simply due to the longer shutter speeds required to compensate. You could turn up the ISO sensitivity, but then you get noisy images...You may find that the maximum aperture at around 200mm is around f5.6, this is still quite poor but far more useful and as long as the light levels allow a 1/200th or faster shutter speed it should also be possible to hand hold the lens without worrying about camera shake. If your camera has seven megapixels or more, then shooting at 200mm and then cropping the shot afterwards to achieve the same view as a 300mm will probably give better results.
Your lens has it's limitations, but a good photographer will learn to work around them when necessary and to embrace them as needed. The 100-300 is known to be a very poor optical performer, but for portrait work a soft lens can be used to good effect. At the end of the day, it's a US$100 lens so you can't expect that much from it but you as the photographer can make a lot of difference by using it creatively.
I hope that I've helped, if so please take a moment to rate my answer.
2/14/2010 2:42:18 PM •
Quantaray...
Answered
on Feb 14, 2010
Quantarary for Canon AF 75-300 mm F4-5.6 25-166-4561
I have been researching this problem and found there's nothing you can really do. Appararently, the quantaray, being an older lens, wasn't made to work with this latest era of cameras. Though it might work perfectly with your older camera, its technology is outdated as it relates to
digital cameras and can't mesh with the latest and greatest. By the way, most of my questions were answered on the
Digital Camera Resource page (
www.dcresource.com
7/16/2009 10:51:46 PM •
Quantaray...
Answered
on Jul 16, 2009
Hello, I get an
Hi
You need to clean the contacts with a dry cloth an alcohol swap etc. of the lens and body. Also try to do
firmware update.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
7/9/2009 7:39:37 PM •
Quantaray...
Answered
on Jul 09, 2009
What camara can i use with a quantaray 100-300 af lens
You can use a Quantaray lens that fits on a Canon EOS film camera body on any Canon EOS camera body - film or digital. Your choice of EOS camera depends on your budget and your needs.
I recommend starting out with a used or refurbished model - let someone else eat the depreciation on the camera. After you have shot with a digital SLR for a while you will have a much better idea what features matter most for your needs and can make a better decision what new(er) model is the best fit for your money. Obviously you know a bit about photography having used a film EOS camera but there are many things that are different about a digital body. One of the biggest differences is that they come out with a new camera several times a year, and a camera body that is just 2-3 years old will be 2-3 generations old, and worth only a small fraction of the price it sold for new - unlike film bodies that held their value much longer.
12/14/2008 8:54:08 PM •
Quantaray...
Answered
on Dec 14, 2008
