20 Most Recent Intuit QuickBooks Simple Start Edition (283063) for PC Questions & Answers
2answers
Save as PDF
While you are saving the file Choose Option Save as PDF file during the process. If faced any issue then follow http://support.quickbooks.intuit.com/Support/Articles/SLN40733 for solution on any PDF recovery tool and if need any help follow Intuit Tech Support .
3/28/2023 8:46:02 AM • Intuit... • Answered on Mar 28, 2023
Quickbooks error 3371
http://support.quickbooks.intuit.com/support/articles/SLN40318 here is link to help your problem if you want to more help step by step visit QuickBooks Tech Support
11/2/2022 7:16:25 AM • Intuit... • Answered on Nov 02, 2022
3answers
Where to download a quickbooks manual in spanish?
Do you know that QuickBooks is now be localised in Spanish language? Here is the solution - http://linguapack.net/quickbooks/
10/5/2022 5:38:25 PM • Intuit... • Answered on Oct 05, 2022
2answers
What is error c=44
QuickBooks attempts to change a damaged transaction or record, you may receive a fatal or unexpected error that contains the value C=44. The C= value in the message indicates the type of error the program has encountered. Typical causes include system lockups and power failures while using QuickBooks. To resolve this issue:
  1. In QuickBooks, select the Window menu and select Close All.
  2. Select the File menu and select Utilities >Verify Data.
  3. If the message "Your data has lost integrity" appears, or the error also occurs while running Verify, select the File menu and select Utilities > Rebuild Data.
  4. When the Rebuild utility has completed, run the Verify utility again to ensure that all problems have been corrected (see step 2).
  5. If the error persists after rebuilding, restore a recent backup that does not generate the error.
9/28/2022 7:04:24 AM • Intuit... • Answered on Sep 28, 2022
3answers
Error message " quickbooks has encountered a problem "
1. Do you have a backup of your quickbooks from before this started happening? If yes, try opening the backed up quickbooks file.
2. Uninstall Quickbooks 2009 completely, then reinstall it and check of updates and install all of them, then try it again.
If the problem persists, please let me know so I can continue to help you. These are the first two things to try and would be the easiest solution.
Thanks for using the FixYa forums!
9/5/2019 12:15:10 PM • Intuit... • Answered on Sep 05, 2019
Serial number
If you purchase the product then QuickBook serial no came with software. If need any more help get Intuit official support http://support.quickbooks.intuit.com/support/ and need any guidance for any solution follow Intuit Tech Support .
8/18/2014 12:23:27 PM • Intuit... • Answered on Aug 18, 2014
Need quickbooks simple start 2010 download
You can downloaded an Updated version on your new Window 7 PC and then back up our previous files and importing them into the new QuickBooks program. For QuickBooks Download follow http://support.quickbooks.intuit.com/support/Static/INF12417.html and read installation help below before. If need help during in any technical solution follow Intuit Tech Support .
8/18/2014 12:05:21 PM • Intuit... • Answered on Aug 18, 2014
2answers
Can't install quickbooks pro 2009
Sounds like you have the QuickBooks Database manager running or the Quick Connect feature still installed and/or turned on. Check and see if this is the problem by going to start and then programs and see if it says QuickBooks anywhere. If it does, slide over to see which of the two listed above are on. Then go to your control panel and uninstall the program. Double check to make sure the "quickbooks" catagorey disappears from your programs and then install the new version you wish to keep.
7/22/2014 10:02:24 AM • Intuit... • Answered on Jul 22, 2014
Emailing of invoice did not go through. Says
ok - hmmm, not much to go on - huh?
when you email an invoice in quickbooks:
a) quickbooks is dependant on having the proper PDF printer drivers (for converting the document from qb format to pdf)
(or)
b) is dependant on having the proper outlook drivers (if trying to use "outlook" option for email delivery
(or)
c) is dependant on having the proper internet explorer drivers (if your trying to use Intuit Email Services)
at the moment, alot of users are reporting problems with windows 7 and compatibility of PDF converter. Could that be your case?
a) If you are using Windows 7 and trying to use PDF - you will find this forum useful:
http://social.technet.microsoft.com/Forums/en/w7itproappcompat/thread/2bd30024-0a64-4f6b-a831-8cb7c1e4cce5
there are three solutions posted:
1. the first solution (has 9 steps) - many users claim works (but the error is not the same as yours)
2. the second solution (has 13 steps) - will work on your error specifically (I know this, because yesturday, I had a client get the same error your getting - AFTER we followed the 9-step instructions.)
3. the third solution, is similiar to intuit's solution, which did not work for us.
If you are a windows 7 users, I would suggest that you try the "13 step" version first.
If you are not using windows 7 or are not using PDF converter, please tell me more about your quickbooks email preferences? are you trying to use Intuit Email Services? or Outlook?
7/21/2012 12:20:41 PM • Intuit... • Answered on Jul 21, 2012
I get an error when I'm closing Quickbooks Simple
Assuming you have Windows XP, please follow these steps:
1. update QB . To update QB,launch Quickbooks and then go to Help>Update QuickBooks. In the windows, click UPDATE NOW.
2. Then go to Start>Control Panel>Add/Remove Programs. Then check mark SHOW UPDATES.
Then find Microsoft .NET framework 2.0 SP1 or SP2. Find update KB976576 or KB576976 and remove it.
3. Restart your computer and then launch and close QB.
ISSUE WILL GET FIXED
In any situation, this issue will never ever effect your QB data file.
If issue remains, reply with QB version and Windows Version?
12/30/2010 7:03:37 PM • Intuit... • Answered on Dec 30, 2010
2answers
I currently have 2007 Quickbooks
You can't transfer the file without contacting Intuit and having them convert it to something that the Quick Start version understands. The quickstart version is not a full version of the software. Your file saved under the premiere version is. So they are not compatible. You can email Intuit from their website and tell them the business telephone number you registered the Premiere software under to recover your license and product number. Ask them to send you a link to download a new copy of Premiere. As long as you are a registered QuickBooks Customer you can always download your product for free if you have your license and product number. You will need both to activate the software once it has finished downloading.
11/21/2010 4:10:26 AM • Intuit... • Answered on Nov 21, 2010
Would like written material to review
You can print the hep topics and make your own manual.
8/11/2010 12:52:10 AM • Intuit... • Answered on Aug 11, 2010
Trying to install Quickbooks Simple Start 2010 on
Simple Start will not install in you have another version of quickbooks. Unistall any quickbooks version.
www.cpahispano.com
8/8/2010 3:41:22 PM • Intuit... • Answered on Aug 08, 2010
Having trouble entering bills
There is no Accounts payable module in the Simple Start Version. You have to upgrade to PRO.
www.cpahispano.com
8/8/2010 3:34:32 PM • Intuit... • Answered on Aug 08, 2010
How do I get an unlock code for Quickbooks
You have to unload a free version from Quickbooks.com
8/8/2010 3:21:42 PM • Intuit... • Answered on Aug 08, 2010
I uploaded 2009 simple start on my computer, used
save what you need and format the hard drive it will be like new
3/19/2010 1:27:59 AM • Intuit... • Answered on Mar 19, 2010
Ever since the update for employee file I get a
Sounds/Looks like the update did not install properly.
You will need to re-install the program and then re-install the update.
2/12/2010 4:40:26 AM • Intuit... • Answered on Feb 12, 2010
I am trying to make a simple entry in the check
thank you for mailing us
you may kindly notice the maximum amount thank you can pay or you may check your web sites terms and conditions
thank you
3/21/2009 12:29:47 PM • Intuit... • Answered on Mar 21, 2009
Intuit QuickBooks Simple Start Edition (283063) for PC Logo
Popular Tags
44 questions posted
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
QuickBooks Intuit
  • QuickBooks Intuit
Most Popular Question
emailing invoice did not go says
  • Computers & Internet
