20 Most Recent
Sony Cyber-Shot DSC-M1 Digital Camera Questions & Answers
MPEG-4 - Sony DSC M1
Try to use the QuickTime player, it has the neccessary codec uploaded and the MPEG4 video files are recognized.
HEEELP for problem E:61:10
Can't believe it! Looked up the error and found this page, and it works, a good hard slap! Incredible, saved me £300 !! Cheers!!!!
Distortion
It's a CCD problem which SONY could fix for free till January 31st (in
Europe), don't know about the America, but you should contact SONY and
ask do they still offer a free imager replacement for this camera as
they did all the time as they came factory faulty.
Hope this helps!
Tom
I get (have) a black screen when I put my camera
Try hitting the display button(the small TV resembling icon in the bottom right of the camera). You may have accidentally pressed it while using your camera and caused it to turn off your display.
Hey..my cam worked fine once i opened it
I'll forward a link to a page where you can view the information to
troubleshoot this issue.
Please click on the link or copy and paste it to open it and follow all the
steps mentioned on the page to troubleshoot this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C193187&fes=true&mdl=DSCM1
Thank you!
When i switch the camera on the screen is black ,i
The CCD imager is faulty and it has to be replaced. A well known problem with the M1. Contact SONY and see if they will replace the CCD imager unit free of charge. They did but recently they stopped the free replacement for a lot of models.
Tom
Scratchy sound so loud you barely can hear normal conversation
Scratch noise is generally caused by failure of one or more Electronics Capacitors located on the board.
But in smaller devices, it may also be due to unstable soldered connections (dry joints)
Please check out the ear set may be there's a cable which just needs to be resoldered correctly.
Which equipment are you using exactly?
Picture blurry almost like looking at thermal
It's a CCD problem which SONY could fix for free till January 31st (in Europe), don't know about the America, but you should contact SONY and ask do they still offer a free imager replacement for this camera as they did all the time as they came factory faulty.
Hope this helps!
Tom
My flash bulb is broken?
The part No with description is give below:
1-479-040-11 FLASH UNIT (FL80000)
To get this part please see the link below:
http://www.partstore.com/Part/Sony/Sony/147904011/New.aspx?SearchTerm=True
Thanks for using fixya.
