20 Most Recent
Sony Cyber-Shot DSC-P41 Digital Camera Questions & Answers
I cant get my pc to see my sony when I plug it in
If your computer is not recognizing this camera, then you may need some drivers to install on your computer. If any CD came with the camera, put that in your computer. If not, then go to this
website and look for the drivers that match your operating system.
My Sony Cybershot dscp41 flash
I own this camera and the same thing happened to me apart from the flash not working now the screen is upside down and flickering i dont know what happened.Im just gonna buy a new camera because this one take clear images as it is only 4 mp.
My camera will not turn
Try to power it using battery and then, DC source. If its not powering, check battery contacts and clean them. If you have a volt measure unit, measure the volts from the DC source and compare the results with the values from the DC unit, also measure the battery and see its status. If you cant solve it in theis basic way, try to go to a professional repair center for a detailed analyzis. Cheers
Okay, so i have a sony cybershot DSC-P41 and i
Hello Kyra
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
When turned on lense does not open
Hello
after dropping it. There are some DIY solutions you could try, but the
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
Regards
Andrea
The LCD is shaky when i turn it on - either in
Hi, thats probably the lens motor mechanism
who is dusty or sand or so inside where the
motor try to extand your lens block to move out
may be if you try to blow some air in the crack arround the base of the lens that could work
,if not you may need a good clean up in the mechanism..
goo luck ,hope that will help.
My camera takes 2mb per picture.
That't is normal, try lowering the your camera resolution and it would lower down the size. I just hope your are not yet on the lowest resolution.
Regards,
Jeep Brainy
Camera powers up but lens cover fails to open
It could be some grit or sand causing the lens cover to not open, so the camera won't initialize. Try cutting a slip of paper narrow enough to slide between the lens opening frame and the lens cover. Move it in and out to clear any grit that might cause the spring-loaded cover to bind. Good luck !
Batery problem
This usually occurs when the camera is exposed to water, sweat, high humidity or if you had leaky alkaline batteries. You have 2 choices to try. 1 take the camera apart and use an old toothbrush with WD40 and scrub the circiut board, you can inspect the battery compartment to see if you have corrosion from leaky batteries and do the above to fix. 2 use the camera as is and remove the batteries after each use.
