20 Most Recent
Mamiya RZ67 ProII Medium Format Camera Questions & Answers
My mamiya rz67, which i have never used before, is
Change the battery! This happened to mine too, I was terrified... never knew it took a battery until then, as I don't have a viewfinder with an inbuilt lightmeter. Unfortunately the rz needs it just to run, this is where the rb actually wins. The battery is underneath, you should be able to get a new one from a camera shop.
I cant seem to change the shutter speed from
Sounds like the electronics are broken. A lot of cameras will fire the shutter at full speed if the electronics aren't working to slow it down. Take it to a professional shop.
I just purchased a used
It is probably the battery. A lot of these cameras have electronically controlled shutters, that automatically fire at the fastest speed possible if there isn't a battery to slow it down.
MAMIYA ZD BACK DISPLAY FULL LIGHT (NO PICTURE) IN
I think the problem is with your Memory Card, try to replace the memory card, Make sure the memory card has been fully inserted, then close the memory card slot cover firmly.
Thanks for using fixya
Good luck and have a nice day.
I have a mamiya RZ
Currently . You need a digital back adapter (approx.$1500.00+ US) then the digital back itself (Approx. 25,000+ US). yes that is correct!. THe RZ67 Pro II needs the DM56 adaptor then the DM 56 back itself. Why not check out the all new RZ22 (22mp) or the RZ33(33mp). The RZ22 is approximately $12,000.00 US and the RZ33 around $18,000.00. Hasselblad also make a 39 and a 50mp digital medium format, expect to pay 2-3 times that of a Mamiya. For a 35mm type dSLR, Nikon just introduce the D3X with 24.5 megapixals. The body alone runs anywhere from $6,500-$8000 US.
Olympus is-50
It sounds like the rewind button on the bottom might be stuck. Refer to page 10 of the user guide and check it with a pencil tip to make sure its not stuck in the pressed position
