20 Most Recent
Sony Cyber-Shot DSC-P31 Digital Camera Questions & Answers
Sony cyber-shot dsc-p31 camera
Connect your camera with PC through USB link and press Camera Menu, you will see PicBridge option there, select / enable it.
Why does my DSC-P31 Camera won't accept Sony
It is an old camera. It was introduced in 2002. The spec's I looked up just say memory stick, and memory included "8MB Memory Stick". I looked the MSAC-M2 up on line and it looks a like it's a "Memory Stick Duo Adapter" not a memory stick. I'd try one that is sold as a "Memory Stick".
Sony DSC-P31
The problem is due to lens block assembly because the slide motor start malfunction and that's why the zoom statr problem, mostly indicate on LCD "Turn off the power and on again".
You have to replace the optical block assembly the detail of the optical is given below:
Part No. Description
8-848-757-01 LSV-780A
Change the given part and enjoy it again as earlier.
Thanks for using fixya.
Sony Cybershot DSC P31
You have to check the CCD and this can be faulty.
The picture may look hazy or lines mayy appear randomly.
Why won't my Cyber-Shot DCS-P31 take pictures?
Actually, try manually turning off the flash and taking a picture. If the shutter works and takes a picture, then suspect that your flash is burned out. Unfortunately it's not a simple task to change a burned out flash tube.
Sony memory stick
Lexar, Sandisk, Sony, Delfin, Dane etc...
http://www.streetprices.com/Electronics/Digital_Cameras/Accessories/Memory/Memory_Stick_128MB/
I think I've seem a Riken or similar as well.
Problem with click button
camera needs new shutter switch .If you can repair yourself and save $$$ .A few outside screws and new switch just plugs in ..new switch is an improved part #147724313 order at sony.com ..goodluck
Black LCD screen on camera
Hi!
Just had the same problem (black display) on a Pentax Optio 330GS(?). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
SONY DSC P31
This need looking at by Sony- anything from a faulty switch to a board fault here.
Can't get pics off the camera!
USB can be funny some times- it has worked so you know what to do OK?
Check-the USB setting- Start/ControlPanel/System hardware/device manager
Rund down to the USB setting and open it check for any yellow makers intcatiing afault - seek help from there.
If you are using a hub or have multiple other devices connected.- disconnec them and use the USB cord direct to computer.
Have you remembered to switch the camera on- it has good batteries- set to upload Huh!
So much to remember easy to forget something
If the trouble wont go away- go buy a card reader and leave that lugged in to usb.
Camera error
Check your manual for for error messages or go the the Tech Support website for Sony
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
