20 Most Recent
Panasonic SV-AV25 Digital Camera Questions & Answers
Connected through a 4-port USB hub
Use of a USB hub for connection does not guarantee normal operation. Try attaching the USB cable directly from the D-snap SD Camera to one of the built-in USB ports on the PC.
9/1/2005 1:42:05 PM •
Panasonic...
Answered
on Sep 01, 2005
USB cable
No. Connect the USB cable after the USB driver is installed.
9/1/2005 1:40:18 PM •
Panasonic...
Answered
on Sep 01, 2005
Serial number required for SD-Jukebox installation
The required serial number for SD-Jukebox installation is located on the paper insert inside the CD-ROM casing. The serial number is 10 or 11 digits long depending on the model. Without the serial number, the Jukebox software cannot be installed on a compatible PC.
9/1/2005 1:39:46 PM •
Panasonic...
Answered
on Sep 01, 2005
Software
SV-AV25 & SV-AV50- SD Jukebox Ver. 4.0, SD Moviestage Ver. 2.5, USB Driver
SV-AV100- MediaStage, USB Driver
SV-AS10- SD Jukebox Ver. 4.0, SD Viewer Ver. 2.1, USB Driver
9/1/2005 1:37:51 PM •
Panasonic...
Answered
on Sep 01, 2005
Folders come up on my screen
The data on the SD Memory Card can be broken up into five separate folders (where applicable):
[DCIM]: The images in this folder (e.g. IMGA0001.JPG) are recorded in the JPEG format.
[MISC]: Files in which DPOF Data has been set to the image are in this folder. Slide show data created by SD-MovieStage Ver. 2.5 are also stored in this folder (e.g. AUTPLY0.MRK).
[SD_AUDIO]: Stores music data files (e.g. AOB001.SA1) recorded by the SD-Jukebox Ver.4.
[SD_VIDEO]: MPEG4 moving pictures are recorded in ASF format (e.g. MOL001.ASF). It can be played back with Windows Media Player 6.4 or later.
[SD_VOICE]: Folder in which voice data files (e.g. MOB001.VM1) are stored.
9/1/2005 1:36:40 PM •
Panasonic...
Answered
on Sep 01, 2005
Format the SD Memory Card
Formatting erases all the data recorded on the SD Memory Card. If an SD Memory Card becomes unreadable, formatting may make it reusable.
9/1/2005 1:35:50 PM •
Panasonic...
Answered
on Sep 01, 2005
SD Memory Card
Yes. The SV-AV100 comes with a 512MB* SD Memory Card. The SV-AS10, SV-AV50 and SV-AV25 all come with an 8MB* SD Memory Card.
*Usable capacity will be less.
9/1/2005 1:35:14 PM •
Panasonic...
Answered
on Sep 01, 2005
Record MPEG4 or MPEG2 motion video
The SV-AV100 records both MPEG2 and MPEG4 motion video.
The SV-AV50 and SV-AV25 record MPEG4 motion video only.
The SV-AS10 does not record MPEG4 or MPEG2 motion video. It can only record QuickTime™ Motion JPEG.
9/1/2005 1:30:32 PM •
Panasonic...
Answered
on Sep 01, 2005
Play back in Windows Media Player
MPEG4 motion video can be played back with Windows Media Player 6.4 or later. MPEG2 cannot be played back in Windows Media Player. Files created with our D-snap Video Cameras are designed for playback with the included MediaStage software and our DMR-E100H DVD Recorders.
9/1/2005 1:29:49 PM •
Panasonic...
Answered
on Sep 01, 2005
