20 Most Recent Panasonic Lumix DMC-LC33 Digital Camera Questions & Answers
try Klomtrix trick this worked with my camera thanks klomtrix
Panasonic Lumix... | Answered on Aug 18, 2015
Press the MENU button, use left/right-arrow to select the wrench-and-screwdriver icon in the upper-right, then use up/down-arrow to select the "i+" icon.
Panasonic Lumix... | Answered on Feb 21, 2015
hello,
i had the same problem , and i tried
Klomtrix solution on the same website, it worked for me thanks Klomtrix sethu
Panasonic Lumix... | Answered on May 07, 2014
You have to get a new camera.
Panasonic Lumix... | Answered on Jan 31, 2014
We may be able to recover the data for you. If it is a logical recovery, we can do it for as little as $59.95! We only charge if we are successful. If we cannot recover the data, we only charge you for return shipping.
http://htcilabs.com/services/data-recovery-services/
Panasonic Lumix... | Answered on Aug 24, 2012
The problem may be simpler to solve. Perhaps you never normally change the setting from iA (intelligent auto), but the wheel with settings can get moved by accident. If it goes around one place counter-clockwise, it puts it onto the built-in memory, it seems. I had the same problem, and it frustrated me for months!
Panasonic Lumix... | Answered on Aug 05, 2012
Replace- at this age not repair is likely
Panasonic Lumix... | Answered on Jul 26, 2012
Lens errors (system errors on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Panasonic Lumix... | Answered on Aug 28, 2011
You could try an SD or SDXC card
Panasonic Lumix... | Answered on Mar 05, 2011
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Panasonic Lumix... | Answered on Jan 21, 2011
http://service.us.panasonic.com/OPERMANPDF/DMCLC33.PDF
Panasonic Lumix... | Answered on Nov 22, 2010
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Panasonic Lumix... | Answered on Nov 09, 2010
Hello
OK, the manual covers this section in detail. Click HERE to navigate to download page.
Kind regards
Andrea
Panasonic Lumix... | Answered on Aug 31, 2010
This error usually comes due to faulty sliding mechanism.Put a bit of force on the focusing lens to push it back into camera casing. That's the reason the sliding mechanism won't work. The lens is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.Or else try out this method.Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Thank you !!
Panasonic Lumix... | Answered on Aug 02, 2010
Panasonic Lumix DMC-LC33 Digital Camera Logo
62 questions posted
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
camera lens will not retract
  • Cameras
