20 Most Recent Panasonic Lumix DMC-LC20 Digital Camera Questions & Answers
Hi,I downloaded the disc which
Try to restart your laptop in some date before this installation (backup restore).
1/11/2011 1:31:43 PM • Panasonic Lumix... • Answered on Jan 11, 2011
Cannot format a maxwell class
The DMC-LC33 is designed to work with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While it fits into the slot it will not work. You need to use SD cards, 2GB and smaller.
8/24/2010 4:35:45 PM • Panasonic Lumix... • Answered on Aug 24, 2010
4answers
MEMORY CARD ERROR
Sounds like the memory card pins are bent. Remove the card and hold the camera up to the light. Look inside the memory slot and see if you can see any bent pins or anythign that is not uniform. There are 2 rows of pins and there whould not be any missing or out of place. It can be hard to see but if there is any that look closer together or laying over thats the problem. Its common and it happens fairly easy. Its best not to remove the card, even though people sugest using a card reader or to save battery life bent pins can trash a good camera.
11/4/2009 4:04:33 PM • Panasonic Lumix... • Answered on Nov 04, 2009
Panasonic DMC-TZ7 BRAND NEW, INSERTED 16GB SDHC
Did you format the card in the camera first to initialize it?
10/14/2009 12:39:20 AM • Panasonic Lumix... • Answered on Oct 14, 2009
Memory card is locked
Make sure taht the write protect notche of the device found on the side part of the card is on.
Alex
7/23/2009 9:15:59 PM • Panasonic Lumix... • Answered on Jul 23, 2009
My Computer no longer recognises the camera as an external device
Did you changed your computer's os? In case you didn't, reinstall to your computer the software CD you received with the camera. Good luck!
9/3/2007 2:10:24 PM • Panasonic Lumix... • Answered on Sep 03, 2007
Problem with LCD
I have encountered this problem before, but with a different camera. Usually when you have a problem with horizontal lines that change over time, the lcd is not the issue. It's usually the data that is sent to the issue that is the problem. I ended up buying a broken camera of the same type from someone and switched out a circuit board. I never had much of a problem after that.
1/22/2006 7:49:47 PM • Panasonic Lumix... • Answered on Jan 22, 2006
Software for Lumix® Digital
No. These cameras store images in a JPEG format and can be used with any software package that can open a JPEG image.
8/31/2005 10:11:46 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
8/31/2005 10:11:03 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
8/31/2005 10:09:59 AM • Panasonic Lumix... • Answered on Aug 31, 2005
DPOF Print Mark Function
The DPOF Print Mark Function allows you to sort through the SD Memory Card and select the images you want to print by electronically marking them. You can then print the marked images on any DPOF compatible printer by hitting the AUTO PRINT button.
8/31/2005 10:09:16 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Unlimited consecutive shooting function
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
8/31/2005 10:08:45 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Effective megapixels
Effective megapixels are slightly less than the total number of pixels normally stated for an image sensor. They represent the actual number of pixels used to record an image.
8/31/2005 10:08:17 AM • Panasonic Lumix... • Answered on Aug 31, 2005
MEGA Optical Image Stabilizer
The MEGA Optical Image Stabilizer helps correct hand movement from shaky hands, one of the main reasons why cameras produce blurry images. Lumix® Digital Cameras with MEGA Optical Image Stabilizer technology have a built-in gyrosensor that detects any hand movement and relays a signal to a tiny microcomputer inside the camera, which instantly calculates the compensation needed. A linear motor then shifts the Optical Image Stabilizer lens as necessary to guide incoming light from the image straight to the CCD. You won't even notice it working—all you'll see are the outstanding results!
8/31/2005 10:07:47 AM • Panasonic Lumix... • Answered on Aug 31, 2005
No battery power remains
On my Leica camera when I turn it on no battery power remains appears why is this?
11/23/2022 9:08:59 PM • Panasonic Lumix... • Answered on Nov 23, 2022
Sony camera service centre pakistan
if theres available online seller in your place try ordering online
4/15/2019 10:59:39 AM • Panasonic Lumix... • Answered on Apr 15, 2019
tip
If you have a older Lumix that does not want to power on
As you know Panasonic issues Firmware Updates that can be downloaded online, and then installed using a computer and an SD card. Some of those Firmware Updates made the cameras refuse to turn on if the battery was not an "approved" Panasonic battery. This significant change was not publicly announced. Panasonic Lumix batteries are available, but there are also dozens of different generic Lumix batteries available, and there is no reference source as to which generic batteries are "approved." Therefore I would encourage you if you have a Lumix camera that is balking on startup to first try a genuine Panasonic Lumix battery that is fully charged. You may find that the only problem was a generic battery that the camera did not care for. (And of course many "Lumix" batteries sold online are not actually Lumix batteries, but merely counterfeits. They have Lumix markings and are often very good imitations on visual inspection.) Another reason some Lumix cameras will not power up is the memory card. Sometimes people use a newer SDHC type card in an older Lumix, and the camera goes into electronic spasms trying to read the newer card. An older plain vanilla SD card will often solve the problem instantly. If a Lumix camera is not powering up with a 8gb SDHC card there is a good chance it will power up immediately with a 1gb SD card. I frequently recommend the Lumix TZ5 to people starting out, as it is a quality build, metal, not toy-like plastic, has more manual controls than most people will ever use, and the engineering is remarkable. I repair TZ cameras and donate them to homeless shelters and domestic abuse safe houses and college photography students and such, as they have full User Manuals available to download, full Service Manuals available for download in PDF format, have a very gentle learning curve, and produce photographs that are superior to many of the current cameras in the 600 to 800 dollar range. Yet a used TZ5 can be bought for 50 dollars or so. Update the Firmware to v 1.2, never carry it in a leather camera case or pocket or purse or with any cloth of any kind, and you have a superb camera for many years.
tip
Caution about Lumix cameras with Japanese language
Some Panasonic Lumix cameras are made in Japan expressly for Japanese Buyers. These cameras may be programmed in Japanese and Japanese only. They cannot in any way be converted to English or any other language. Most Lumix cameras have a menu option that allows choice of language. That option is not available in some Japan-originated cameras. I see Lumix cameras often on eBay that are listed as "From Japan". Be careful. I advise you ask the Seller to take photos of the LCD screen of that specific camera being sold with the menu choices showing, to be certain that it is not a Japanese language only camera. Insist also on a photo of the bottom plate. Is it in Japanese? Sellers have told me in the past "You can choose any language easily". Yes, that is true. If the Lumix camera was made in Japan for export. But if it was made in Japan for use in Japan it may not be true.
Panasonic Lumix DMC-LC20 Digital Camera Logo
Popular Tags
15 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
memory card locked
  • Cameras
