20 Most Recent Panasonic Lumix DMC-FX8 Digital Camera Questions & Answers
4answers
There is a spot on the top left hand side of the LCD monitor, and this spot also appears on the prints
Looks like dust must have gotten onto the CCD sensor (or, more specifically, onto IR-cut filter on the sensor). The dust enters the lens through the gaps between zoom barrels and sometimes ends up on the sensor-which is what most probably happened here.
There are 2 ways I know to remove the dust. 1st way-it might sound silly, but try sucking the dust from the camera with your mouth around the closed lens :) Make sure you don't blow any air in. This worked for me a few times. Note that sometimes it might make the problem worse as you might move other dust particles onto the sensor.
If 1st way didn't help then you can try directly blowing the dust off the sensor. This should only be attempted if you're happy with partial dismantling your camera and are ok taking the risk of ruining the camera further. Although in my opinion lumix cameras are generally fairly easy to repair, you will need steady hands and patience to attempt this. If you are happy to proceed, do the following:
1. unscrew the screws holding the back of the case
2. lift the case carefully a bit making sure you don't break the ribbon cables going to LCD and backlight
3. undo the LCD and backlight ribbons (there are black flaps on the connectors, these gently flip upwards)
4. gently remove upped logic board. Try to pry it in stages from all sides, don't just pry it up in one go from one side or you might damage the connector. (I learned the hard way ;)
5. on the bottom logic board you'll see 2 connectors, undo the upper one to release the ribbon going to the sensor (note that this is not absolutely necessary if you're happy cleaning the sensor without disconnecting it-it can be done, the ribbon is relatively robust.)
6. the sensor is held by 3 tiny star screws. if you don't have the exact screwdriver you should be able to use a small flat screwdriver to carefully unscrew them. Do the screws bit by bit, i.e. unscrew 1st one a bit, then unscrew 2nd one a bit, and so on
7. there is a small spring underneath the sensor assembly, make sure you don't lose it :)
8. once the screws are undone you have access to the sensor-lift it up. Under good light you should be able to see the dust bits. Use a blower to get rid of them.
9. that should be it. put the camera back together. figers crossed it will power up and the dust problem will be gone :)
NB. You might have come accross horror stories of people being electrocuted by flash capacitors when repairing cameras. This might indeed happen. It's not easy with FX8 though: To get electrocuted here you would need to undo the top plate, unscrew the switch logic board and remove protective tape off the flash circuit, then touch the capacitor contacts :) Don't do it of course. Not worth it.
Good luck,
Raf
1/7/2023 1:00:46 PM • Panasonic Lumix... • Answered on Jan 07, 2023
DISPLAY HAS GONE VERY DIM.
You can change the brightness of the display in the setup menu.
8/31/2018 3:39:18 PM • Panasonic Lumix... • Answered on Aug 31, 2018
Get photos off my panasonic lumix
Photo transfer from the camera to a computer is usually done with a USB cable. For detailed instructions on how to transfer the pictures, check out the user manual: Panasonic DMC FX8 manual
1/17/2015 6:42:23 PM • Panasonic Lumix... • Answered on Jan 17, 2015
Camera will not turn on
Try taking out the battery, then putting it back in. Also consider using a replacement battery to see if that's the issue. Your problem might be addressed in the user manual for the device: Panasonic DMC FX8 manual
12/6/2014 2:36:18 AM • Panasonic Lumix... • Answered on Dec 06, 2014
How to change setting language
Well, what language do you have it in now? The option should be in the settings of the device. Do you have a user manual in your language, or any for that matter? If not, you can check out the manual here: Panasonic DMC FX8 manual
12/6/2014 2:30:29 AM • Panasonic Lumix... • Answered on Dec 06, 2014
3answers
Camera doesn't respond
Hey bro I have exactly the same problem, when i turn on the damn thing it just zooms right out and just keeps scrolling through the options. I think that it has to be some sort of software problem, there must be a way to reset it!
9/28/2014 6:18:03 PM • Panasonic Lumix... • Answered on Sep 28, 2014
2answers
Can a panasonic dmc-fx8 use a sdhc memory card
This camera cannot be upgraded to read SDHC cards. The maximum is 2Gb Secure Digital.
9/20/2014 7:52:59 PM • Panasonic Lumix... • Answered on Sep 20, 2014
Can i use a sdhc card with my panasonic dmcfx8
Your question carries insufficient details for anyone to provide you some help! Do up your question properly and post it again if you really want some free help from this site.
9/19/2014 7:19:26 AM • Panasonic Lumix... • Answered on Sep 19, 2014
When i press the button down half way, the camera
The camera is trying to focus, but can't. If you're trying to shoot something very close you may need to back away from the object. Try focusing on something in the distance to see if you can get the camera to focus and shoot.
10/22/2013 7:23:54 PM • Panasonic Lumix... • Answered on Oct 22, 2013
3answers
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
You may fix the memory card error and recover your files by follow this memory card recovery guide which helped me last time:Fix memory card error and recover data from memory cardgood luck!
5/24/2013 2:09:55 PM • Panasonic Lumix... • Answered on May 24, 2013
Camera not connect to computer
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1/17/2013 3:37:10 PM • Panasonic Lumix... • Answered on Jan 17, 2013
2answers
The photos aren't downloading from
HI,
Please reinstall your camera drivers.Uninstall it first from the control panel add/remove programs and then with the disc provided to you install the drivers.
1/2/2013 6:39:57 PM • Panasonic Lumix... • Answered on Jan 02, 2013
How to charge battery through pc
You can't. The camera does not include any battery charging circuitry. You must use the supplied battery charger (or a third-party compatible).
4/25/2012 5:18:22 PM • Panasonic Lumix... • Answered on Apr 25, 2012
Replacement backlight for dmc-fx8
PANASONIC LUMIX DMC FX8 LCD DISPLAY Replacements our being sold on e-bay, for $30. I think this is what you our looking for? If not I hope you have success elsewhere. God bless...
2/21/2012 7:28:36 AM • Panasonic Lumix... • Answered on Feb 21, 2012
Do not have disk to reinstall drivers
The Panasonic website doesn't have drivers for this camera listed. Check the link here: http://panasonic.com.au/Support/Customer+support/Downloads+and+documentationMost likely this camera is plug'n'play and doesn't require specific drivers.
11/12/2011 8:32:15 PM • Panasonic Lumix... • Answered on Nov 12, 2011
I want to upload photo graphs onto my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
10/26/2011 5:03:46 PM • Panasonic Lumix... • Answered on Oct 26, 2011
Panasonic Lumix DMC-FX8 Digital Camera Logo
120 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
message memory card error memory card
  • Cameras
