20 Most Recent
Razer Rz01-00280100-r3u1 Naga Mmog Laser Gaming Mouse Questions & Answers
My mouse isn't moving on the screen
Hi I had this recently do you have a small oblong button right below the spacer bar you might have pressed it by mistake, while dusting etc, this freezes the pointer, also on my previous laptop I had the same problem but no button, so that was fixed by closing it down, unplugging it, removing the battery and replacing then switching back on, very important though to unplug from the mains......
8/27/2012 9:39:13 AM •
Razer...
Answered
on Aug 27, 2012
New razer headset..flashing green and not comnecting
If your Razer wireless headset is flashing green and not connecting to your Xbox One, there are a few things you can try:
- Reset the headset: Try resetting the headset by holding down the power button for 15 seconds until the light on the headset turns off. Then, turn the headset back on and try to connect it to your Xbox One again.
- Check the Xbox One controller: Make sure the Xbox One controller is properly synced with the console and that the batteries in the controller are fully charged.
- Check the Xbox One settings: Make sure the Xbox One settings are properly configured for wireless headsets. To do this, go to Settings > Display & Sound > Volume > Party Chat Output and make sure "Headset" is selected.
- Check for interference: Make sure there are no other wireless devices or routers nearby that could be interfering with the headset's signal.
- Contact Razer support: If none of the above solutions work, contact Razer support for further assistance. They may be able to provide additional troubleshooting steps or help you with a replacement if necessary.
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
Yesterday
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
