20 Most Recent Motorola Mobility OEM Bluetooth USB PC Adapter with Widcomm Software CD 98578/98578H V3 V710 V600 Questions & Answers
you can get updates and installations for your phone software here, they automatically load the drivers when you connect the phone to a usb port via the cable. http://direct.motorola.com/ENG/SoftwareUpdateSummary.asp?country=GBR&language=ENG&web_page_name=SUPPORT&strCarrierId=&strPhone=RAZR%20V3&strCable=Mini%20USB%20Data%20Cable
Motorola... | Answered on Dec 09, 2011
go to control panel or device manager
Motorola... | Answered on Sep 27, 2011
Have you tried using the RESET button? It should be identified as to
location in your owner's manual.
Motorola... | Answered on Aug 21, 2011
hi..
if you have windows xp then you need to turn your computer as soon as you do that before you see the windows xp logo hold down the control key and keep tapping f11 key.it should take you to the screen fro factory settings and if it is windows vista then you can go ahead and press f8 and then choose repair my computer,hit enter which will then prompt you to login in once you log in it will tell you to choose the options from the options listed below choose the one which says restore factory default...you computer will be restored to factory settings..
vedhick
Motorola... | Answered on Dec 18, 2010
Dell Tec told me to choose "To set up Windows XP now" (with Operating System CD in drive) If it doesn't work try Dell Tech Chat. I kept getting "Windows could not start because the following file is missing or corrupt: <Windows root>\system32\ntoskrnl.exe. Please re-install a copy of the above file." (I tried to restore to original factory, followed directions, f12 boot from CD but when I get to "Agree to Licensing Agreement" none of the keys work except ESC.) I was able to get on the Dell Tech Chat at http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&cs=19&l=en&s=dhs (you need your Service Tag) tried same steps but keys would not work so they sent me a new hard drive that I can install myself. Evidently there is no way to fix this. Tech says wireless will work with new hard drive. Is your warranty active? I always get SquareTrade.com (cheaper than most) warranty. They fix or give you what you paid. Everything I buy breaks & sooner than you would think.
Motorola... | Answered on Jan 11, 2010
You shouldn't need a disk, but you will have to make sure you have downloaded and installed the latest usb drivers and any software updates available for your phone and/or operating system. See also here and here. Or go to this page.
Also have a look at the user's forum for answers that relate specifically to your phone model.
If you're trying to download the photos without the Motorola phone tools, it will help to have image viewer software installed on your computer that will be able to download the photos into a folder where you can sort and access them. One free program that works well for me is Fastone Image Viewer, though I haven't tried it with your phone...The Image Viewer software will recognize your phone as if it were an external storage device or camera with photos stored on it, and you simply transfer the files you wish to save to your computer...
If you want to use the Motorola Phone Tools, you'll have to purchase the cd. See here. Then search the knowledge base for "picture transfer", and see in particular this article.
Good Luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Motorola... | Answered on Oct 09, 2009
There is none, you need a cd...but you might be able to restore is to the factory settings by using "System Recovery".
Motorola... | Answered on Sep 14, 2009
If you have the USB cable that came with the phone you can simply connect it to the phone and the other end to the USB port of your computer and when its already recognize by the computer you can now transfer file from phone to computer...
Motorola... | Answered on Sep 10, 2009
www.motorola.com under support for your phone would have the driver and software, thanks and please rate my solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Motorola... | Answered on Aug 19, 2009
Your laptop came with a set of restore disks. Dell does not have a 1 step process. You need to format the hard drive and reinstall windows. You will need to install several drivers as well as the other software that came with it.
Motorola... | Answered on Jul 17, 2009
right click on the photo and then click save photo as....and put what you want to save it as and it will save it to your computer.!.
Motorola... | Answered on Jul 11, 2009
Go to the Motorola website to get the software.
Motorola... | Answered on Jan 24, 2009
my recommendation
would be to use the USB wire. it is better.
Motorola... | Answered on Jan 09, 2009
It would help to know which Motorola phone you have. But sounds to me like you have only the Motorola Update software, meant to only upgrade your phone to latest Motorola operating system. In order to access your pictures, depending on your phone model, you will most likely need the Motorola Phone Tools application. Unfortunately it does not come with the phone. It can be purchased here: http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=600960 You can also check www.modmymoto.com for aftermarket applications to access your phone. P2KCommander is one of the more popular programs.
Motorola... | Answered on Jan 08, 2009
I would like to say don't transfer files with bluetooth because in high use areas you will get interference which corrupts the transfered file. But, people seldom care about why things happen they just want them fixed. well the best thing I can say is to try your transfers in an are where no one else has bluetooth or WiFi. I know this does not help, but there is a reason bluetooth is call all band or all spectrum noise.
Motorola... | Answered on Jan 07, 2009
Go to this site for latest drivers, if your cd is not responding, but try usb cable in a different port http://direct.motorola.com/ENA/SoftwareUpdateSummary.asp?country=AUS&language=ENA&web_page_name=SUPPORT&strCarrierId=&strPhone=V3x&strCable=Mini%20USB%20Data%20Cable
Motorola... | Answered on Aug 24, 2008
Hello adelino,
These pictures and songs are probably defaulted there and cannot be removed. Your best try is to use your computer to try to delete them instead of doing it over the phone.
Terry
Motorola... | Answered on May 27, 2008
do you look for devices on your computer or on your phone?
Motorola... | Answered on Feb 28, 2008
Motorola Mobility OEM Bluetooth USB PC Adapter with Widcomm Software CD 98578/98578H V3 V710 V600 Logo
29 questions posted
Top Motorola Mobility Computers & Internet Experts
Tom Chichester
JessicaChane2345
FiFo
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Computers & Internet
Most Popular Question
motorola v3 free software upgeade
  • Computers & Internet
