20 Most Recent
Smeg 23 in. SE64 Gas Cooktop Questions & Answers
Smeg SAR134A/X does not ignite.
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
Flame leaking under lower ring. Common?
no it is a problem with the hob consider this as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
New cooktop ! long flame yellow tips black
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself
oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
My smeg cooker is brand new! after cleaning it -
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
Auto ignition won't stop
If you accidently got the igniter switches wet, this will happen. If you lose a good ground on he unit this will also happen. Check both of these to see if that helps.
