20 Most Recent
GE (JASHO96273) Questions & Answers
Networking
Against my better judgement, because crimping doesn't work half the time, here's the color code.
A 4-pair Cat-5e or 6 cable has BLUE, ORANGE, GREEN, and BROWN pairs. The ones with the most white are called Tip. In a 568B wiring scheme, they go 54361278.
or, like this
1 2 3 4 5 6 7 8
wo ow wg bw wb gw wbr brw
Data is actually carried on pins 1 2 3 and 6.
If you wire the other end of the cable the same way as above, it's called a straight through cable.
If you reverse the orange and green pairs, it's a crossover cable. This is also the pattern for 568A
1 2 3 4 5 6 7 8
wg gw wo bw wb ow wbr brw
Getting the wires to untwist and behave is half the fun, that's why we use special plugs when we absolutely have to crimp. Otherwise, we use a jack and patch cord.
Carl
Changing door direction
Is this a refrigerator? The way it stands, your statement is just that, a statement, incomplete at that. I don't see a question and the RJ-11 in the picture you selected is not much help.
If this is a refrig and you want to make a right hand door open on the left, (or ther other way around) it should be no problem. You will need a screw driver or a nut driver depending on the fasteners. Clean out the device, remove the top hinge, rock the device back to remove the bottom hinge and move it to the other side. Do not lay the device on its side or back as this will adversely affect the machinery
GE Profile refrigerator TBX22pr
Just try to clean the water filter or replce it. Try to replace your ice maker my its old and need to be replace. If it is still not working, contact a appliance technician and let him check your refrigerator
GE profile fridge
What you can do is either replace the fill tube, with a plastic one,, or you can install a filter.
GE profile fridge
Are numbers being displayed at all? If you want to confirm whether they are wrong or not, try putting a thermometer inside the fridge for about 10 minutes and check it against the temperature displayed. If it's wrong then it's probably the temperature sensor and would need to be replaced.
I suppose it's a long shot but could it be displaying 18 and feels more like 65? (Celcius vs. Farenheit)
Ge tfx20ja refrigerator
Does the compressor run? Or run intermittently? Are there any clicking sounds? Possibly the start relay is bad. It's a small box attached to the compressor. There should be 4 letters after the model number that you'll probably need to get the correct part.I'd give these folks a call: http://www.partstap.com/searchresults.aspx?model_or_part=TFX20JA
GE Stove JCS968WK1WW display shows HR9.99, and no display controls work
Try a GE Control Panel Reset
This should clear the error codes:
Power off the unit, wait 5 minutes then restore the power.
Press the broil and bake keys simultaneously and "SF" will be displayed.
Press "Hr. Down" and "Minute Down" keys simultaneously for 3 seconds, then the time of day will be displayed.
Press "Temp Up" and "Minute Up." The control panel will display the following:
Go blank briefly
Display all segments briefly
Display "LOC REF" briefly
Display all segments again for 30 seconds
Display "LOC REF"
Acknowledge the "LOC REF" by pressing the "Hour Down" and "Minute Up."
Test control pads. Oven should now function.
Display on GE REFRIGERATOR
If the display on your GE refrigerator is not working try with this step:
1. Check the power: Make sure the refrigerator is plugged in and the outlet is working. If the display is completely dark, there may be a problem with the power supply.
2. Reset the unit: Try unplugging the refrigerator for a few minutes and then plugging it back in. This can sometimes reset the display and clear any error messages.
3. Check the temperature settings: Make sure the temperature settings are set correctly. If the temperature is set too high or too low, it can affect the performance of the refrigerator and cause the display to show an error message.
4. Consult the user manual: If the display is still not working or showing an error message, consult the user manual for troubleshooting tips and contact information for customer support.
If none of these steps resolve the issue with the display on your GE refrigerator, it may be necessary to have a professional technician inspect and repair the unit.
I just changed the pad and re attached the lead wire on my ge seer 1000 7 day Holter monitor and the light is orange. What does this mean?
It is not uncommon for a Holter monitor to have a status indicator light that indicates the current status of the device. The color of the light and its meaning can vary depending on the specific model of the Holter monitor.
In general, an orange light on a Holter monitor may indicate that the device is in a standby or charging mode, or that it is preparing to record data. It is important to refer to the user manual for your specific Holter monitor to determine the exact meaning of the orange light and any other status indicator lights that may be present on the device. The manual should also provide instructions on how to properly operate and care for the Holter monitor. If you are unsure about the meaning of the orange light or how to use the device, you should contact the manufacturer or a healthcare professional for assistance.
Will a gear head wireless mouse work with a GE 98614 wireless keyboard
I am making over $13k a month working part time. I kept hearing other people tell me how much money they can make online so I decided to look into it. Well, it was all true and has totally changed my life. Last month my pay check was $12712 just working on the laptop for a few hours.This is what I do, Read more here>>>HERE www.bizrecorder.com
